Go Back   Automotive Forums Car Chat > Cars in General > Exterior | Bodykits | Lighting | Aerodynamics
Exterior | Bodykits | Lighting | Aerodynamics Discuss different body kits, body work in general, and all types of exterior modifications.
Old 02-15-2005, 10:47 PM
mrpatis mrpatis is offline
Send a message via AIM to mrpatis
Unhappy Problems with Philips HID Xenon kit! HELP!
I recently purchased a set of JDM housing headlights for my 94 Accord and it came pre-installed with a Philips D2S/D2R Xenon kit, including bulbs and ballasts (sounds sweet right?) Problem is, when I hook everything up, the HID's won't fire up. The high-beams work fine (they are halogens), but I get nothing from the Xenon's. I suspect that either the bulbs are burned out (doubtful, because xenon bulbs are supposed to last a very long time, and BOTH sides are out), or I'm missing a key component of the HID system. FYI, here's what was included when I received the headlamps: L and R housings, a pair of Philips D2S/D2R ballasts, and a pair of Philips 6000k bulbs. I disconnected the stock headlight and hooked up the stock 9006 wire harness to the input in the ballast and ensured that the xenon bulb was properly connected to the output side of the ballast, but when I started up my car and switched on, I got nothing at all. Can somebody help me or at least point me in the right direction??? I don't know too much about Xenon kits so please enlighten me! THANKS!
Old 02-17-2005, 11:33 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Problems with Philips HID Xenon kit! HELP!
Try to find some way of getting ahold of the jap-spec wiring diagrams. My guess is that the xenon wiring included beefy wiring and some solenoids or relays to supply enough juice to those ballasts. Without enough burst amperage, they don't fire very well.
Just a shot in the dark, but I know when you buy an aftermarket HID kit from like Phillips, they stress over and over that you can't just hook up the leads to the factory wiring. I think they recommend 10 ga, but I'm sure you could do 12ga. They also either include or recommend at least one 30-amp relay per ballast, each supplied by that heavy wire.
Dragging people kicking and screaming into the enlightenment.
