Old 02-09-2005, 08:26 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Time to get caged!
I've got a generous check coming back from the gov't soon, so I can finally afford a roll cage. I really dont want to spend more the $500 on the cage, however. I know a want an 8-point, nothing more or less. Mild Steel vs. Chrome-Moly, whats the differences? Prefered brands?
Also, should I buy a pre-bent cage kit or should I have it custom fab'd at a local welding/racing shop? I may do the welding myself if I get one in the mail, as I am a certified welder. Opinions all?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 02-09-2005, 08:54 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Re: Time to get caged!
I prefer chrome-moly, and I would also prefer custom work. Problem is, custom work cost money.
My ride at my site Silverstangs.
Old 02-09-2005, 09:18 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
From what I've seen in my area. Shops charge 600-900 for a good custom 8 point cage.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 02-10-2005, 12:41 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Chrome-Moly can meet track specs and be a lot lighter vs. Mild Steel but chrome-moly cost a lot more.
I like to just get pre-bent which gives you a good base and then modify them a little bit for what you want. I like S&W Race Cars cages so check them out.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 02-10-2005, 06:17 PM
351wStang's Avatar
351wStang 351wStang is offline
I dont know much about cages. But I do know that you want them to fit as tight as possible in order to give the most strength.
1969 Cougar
357w & TKO - 475hp
Old 02-10-2005, 07:19 PM
I checked em out. Good prices, a lot of em too. But no Chrome-Moly option? Also, what do you mean by modify?
Old 02-11-2005, 10:36 AM
GTStang's Avatar
Stang Guy
Re: Re: Time to get caged!
They have Chrome-moly but you have to call for pricing.
By modify I mean you tweak it a lil. My 10-point S&W cage's bars ran infront of the seats at an angle higher than I liked for a car that was still driven a lot on the street. So at my work I had them change the bars that ran across the doors as low to the floor as possible and horizontal instead of an angle to make getting in and out as easy as possible while still passing tech. Also since my hatch was now useless for the look factor we added two bars to make a X in the back which looked mean in the hatchglass from behind.
Old 02-11-2005, 11:27 AM
HiFlow5 0's Avatar
Stanger
Re: Re: Re: Time to get caged!
You miss that car!!!
-2013 Ford Flex
-1999 Ford F150
Old 02-13-2005, 10:27 AM
eillob's Avatar
eillob eillob is offline
Im definatley gonna have to put one in mine. Especially having a convertable. Im thinking of just somthing along the lines of a nice 4 ot 6 point.
What type of welder are you gonna use? Stick or mig?
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 02-14-2005, 06:59 PM
So I just got quoted from a local chassis shop(highly recommended) for the install of an 8-point moly cage(providing it myself) for $450. Does that sound right?!! WoW
Old 02-14-2005, 11:53 PM
GTStang's Avatar
Stang Guy
Sadly yes... think they have to take all your interior out weld it in and then put the interior all back in wit modifications to fit round the cage.
Old 02-15-2005, 12:12 PM
No, thats just it. I told them in my email that my interior was already stripped and I would put it back together!
Old 03-08-2005, 12:29 PM
Now I'm not really sure whether I want the chrome-moly over the mild steel. If I get the mild steel bar I'll save $200, which I can use on some other things I really need. I want to get a hood-lift kit and an electric fan(my fan clutch is bad anyways).
So anyways, how much of a weight difference is there between the two metals? Also, what other pros-cons, if any, are there comparing the two? Sorry to keep asking, but I just dont know what to do right now.
Old 03-08-2005, 03:35 PM
GTStang's Avatar
Stang Guy
I don't know what the weight savings is I just know the chrome-moly is stronger so you allowed to use a thinner(lighter) pipe vs mild steel.
