Old 02-08-2005, 09:14 AM
matt17 matt17 is offline
bellhousing
Is there any differeces between the srod 4-spd bellhousing and the bell used on the t-5?If so what is it and can you ake them interchange?thanks
Old 02-08-2005, 05:31 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: bellhousing
Yes there is and no you can't to the point where it is worthwhile.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 02-09-2005, 05:25 AM
Re: bellhousing
i'm not going to run a srod,i have a t-5!but the only bellhousing i have right now is out of a 83 gt! i know the 83 used a 10 inch clutch where the t-5 has a 10.5,just wanted to know if anyone has used the older bell on the t-5!
Old 02-09-2005, 09:22 AM
87turbostang 87turbostang is offline
Re: bellhousing
The SROD bellhousing uses the Tremec bolt patterns, and will not work on the T-5
Old 02-09-2005, 06:00 PM
GTStang's Avatar
Stang Guy
Re: Re: bellhousing
You know 1/2 way through 83 they put T-5's in the GT's.
Old 02-09-2005, 07:28 PM
Re: bellhousing
yep!the svo was on it's way,wish this was the case,half to go scrounge a bellhousing up,just curious,sense the srod has a tremec bolt pattern will the 83 bell fit a newer tremec!!!
Old 02-10-2005, 01:42 AM
GTStang's Avatar
Stang Guy
Re: Re: bellhousing
The SROD-4 bellhousing will work for a Temec or a Ford 4-speed Toploader.
