Old 02-03-2005, 10:34 PM
2crunk's Avatar
2crunk 2crunk is offline
Gas Gauge Woes
The first thing i noticed when i bought my '87 5.0 was that the gas gauge will play tricks on you. Lets say it has a half a tank of gas and the gauge shows a half a tank......5 mins later it will say full. It does this all the time going to where it is supposed to be and back to full again. Why is it doing this? Anyone else had this problem?
Check out more pics and info on my Stang at: http://www.cardomain.com/profile/2crunk
Rest In Peace Hypsi87, you'll be missed.
Old 02-03-2005, 10:45 PM
dampachi's Avatar
dampachi dampachi is offline
Banned
Send a message via AIM to dampachi Send a message via MSN to dampachi Send a message via Yahoo to dampachi
Re: Gas Gauge Woes
Could possibly be your sending unit or your gauge float.
Old 02-03-2005, 10:48 PM
2crunk's Avatar
Re: Gas Gauge Woes
Whats the sending unit?
Old 02-04-2005, 12:47 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
It could also be a problem behind your gauge cluster itself. Theres a plastic sheet on the back of the cluster with built in circuitry. If its not making contact properly, the gauge can be real weird sometimes. I had to fix mine before.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 02-04-2005, 10:28 AM
2crunk's Avatar
Re: Gas Gauge Woes
I'll look on the backside of the cluster, how did you fix yours? Or did you just put another cluster in....That reminds me, my speedo stops at 85 and i know they make speedo's that go to 145, how can i callaborate my speedometer so that it will show the correct speed if i put one of these in?
Old 02-04-2005, 01:53 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: Re: Gas Gauge Woes
You need to either buy a 140mph speedo or the only place I know that recalibrates 85mph to 140mph is Brother's Performance for like $35+ shipping.
About the gas guage thing my kinda likes to jump around and sometimes owrk but my dummy fuel light is always worked fine. So when that is on and stays on I know I need to put gas in within 20 miles.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 02-04-2005, 05:56 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
Re: Gas Gauge Woes
i had the same problem when i bought my 87 gt. the gas gauge would read a full tank one minute and the next time i looked at it, it was on empty. so i replaced the sending unit in the tank and it fix the problem.
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 02-04-2005, 11:26 PM
2crunk's Avatar
Re: Gas Gauge Woes
Where exactly is the sending unit? Is it inside the gas tank? Do i need to pull the gas tank to replace it?
Old 02-05-2005, 01:15 AM
Arrow Re: Re: Gas Gauge Woes
Yes and yes.
