Old 02-01-2005, 12:05 PM
Laaars Laaars is offline
Peel of masking tape
Hi!
I have just painted a VW Golf, and used masking tape to make some flames on the side. Tha paint is now so dry that I can touch it without getting paint on my fingers or leaving marks. But I guess it's not 100% dry since it's just 2 hours since i painted it. (Spray paint).
Can i peel of the tape now? Or may this leave some ugly marks in the edges?
Old 02-01-2005, 12:10 PM
cj_baller13's Avatar
cj_baller13 cj_baller13 is offline
Send a message via AIM to cj_baller13 Send a message via Yahoo to cj_baller13
Re: Peel of masking tape
Although i have never used masking tape with a spray can i would reccomend leaving it for at least 5 hours just to avoid any major catastrophies
Christmas Project- Beetle Cabriolet Diorama
"seven straight summers, critics might not admit it, noboddy in rap did it, quite like i did it. if u did it i dont it before you, if got it i had it got mad at it and not want it no more..." Jay-Z the gift and the curse
Old 02-01-2005, 01:48 PM
freakray freakray is offline
AF Modelrater
Actually the longer you leave the paint to dry the harder it will be to remove the tape clearly.
Personally, I remove masking tape between 10 and 20 minutes after I spray, I certainly wouldn't wait 2 hours, let alone 5 or more.
If you've waited 2 hours, I recommend you remove the tape immediately and extremely carefully.
AF User Guidelines
Old 02-01-2005, 01:49 PM
drunken monkey's Avatar
Razor Sharp Twit
what masking tape do you guys use?
do you all use the tamiya tape or just stuff from the diy store?
every time i go into B&Q i see all types of masking tape and the low tack one (the name) appeals bu it doesn't feel like it's sticky enough to really seal against painting.
then there's the blue £m tape that is quite expensive.
at the moment, i'm just using, very carefully, normal 3M masking tape (the biege one).
no scares yet.....
Old 02-01-2005, 02:04 PM
AF Modelrater
I use strictly Tamiya masking tape, it's the best stuff I've used although there is one other brand I know comes highly recommended but the name escapes me right now.
AF User Guidelines
Old 02-01-2005, 02:25 PM
builder's Avatar
builder builder is offline
Re: Re: Peel of masking tape
if you use tamiya masking tape or you bye some masking tape from a car paint outlet if you dont have a local outlet see if there is a body shop nearby (car painter) might be able to bye som of them
Old 02-01-2005, 02:47 PM
AF Modelrater
Re: Re: Re: Peel of masking tape
What?
AF User Guidelines
Old 02-01-2005, 02:56 PM
Vric's Avatar
Vric Vric is offline
True. With Tamiya paint, masking should be removed in the first hour.
It's tricky, but help the paint to not crack when you remove the tape.
Old 02-01-2005, 03:00 PM
Jaymes's Avatar
Jaymes Jaymes is offline
I use Tamiya masking tape for fine details like the window trim, and use a no-name brand masking tape that I bought from the Dollar Tree (for a dollar) for general areas.
Old 02-02-2005, 07:34 AM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
Ahem, I do hope english is not your first language! Any chance of translating this so we can actually read what you're supposed to be saying?
Old 02-02-2005, 08:25 AM
Dublinguy's Avatar
Dublinguy Dublinguy is offline
Re: Re: Re: Re: Peel of masking tape
He is Norwegian so I take it English isnt his first language. I agree it was a bit hard to read but just about understandable.
On the masking issue, like Ray said masking is best removed before paint dries too much. I also only use Tamiya tape.
Old 02-02-2005, 11:13 AM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
I've been using regular masking tape for years, but just got some 3M and Tamiya tape and I'll see how they work. R/C painters swear by the 3M stuff, and if the Tamiya tape is what I think it is (Similar to the material they include for window masks in R/C bodies) then it should be great stuff too.
Don't forget to use a new blade to cut yourself an edge, and never rely on the edge of the tape as it comes off the roll: Lint and stuff gets stuck in it and will befoul your paint job.
Old 02-02-2005, 01:16 PM
builder's Avatar
no im not the best of writhing english ,ok ill make this easy`er for you
if you find a place where they spray paint cars you know real cars forexample ask a car dealer if they paint damaged cars in them self of if they send them to a car painter ither way ask if you can bye some masking tape from them i use the same tape that pro car painters use and its the best i know i am educated as one
there was that better?
Old 02-02-2005, 07:57 PM
Don't worry about your Engish: It's MUCH better than our Norwegian.
Old 02-03-2005, 11:02 AM
builder's Avatar
thanx steve : i dont know the english word but i have a problem with writing and reading the work for it starts with d
