Old 01-31-2005, 06:21 PM
Pimpdady753 Pimpdady753 is offline
new dis question
ok i just thought about this, i took my old dis out. you know the little thing that spins and sends the spark to the cylinder, well i dont remmeber where it was when i took it out, what am i soppose to do, does it matter i realy do think it does matter. When i put it back in or i put a new one in. i dont have to take the hole enging apart do i, i hope not. could some one help me.
Old 01-31-2005, 10:20 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Re: new dis question
Go get another one from your local Autozone........ cap and rotor......
My ride at my site Silverstangs.
Old 02-01-2005, 02:51 AM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
usually the TFI module plug faces the front of the engine.
to determine the correct position, remove the number one spark plug (front, passenger side). place your finger in the plug hole and have a friend crank the motor manually until you feel air being compressed. when the compression stops, stop moving the motor. then, index the rotor so that when the dist is dropped in, it points toward the post for the #1 spark plug wire. secure the dist with the clamp and attempt to start the motor. if it backfires, retard the timing significantly (rotate the dist clockwise for retard, counterclockwise for advance). if all else fails, fool around with the timing till it starts. remove the spout connector (near the dist plug, 2 small yellow wires) and set the timing to 10 degrees before top dead center. tighten the hold down bracket bolt and plug the spout connector back in. should run fine.
why did you remove the dist to begin with?
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 02-01-2005, 04:12 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Just as a note you should write out distributor cause DIS=Ford Distributorless Ignition system. No biggie just like the hole NOS isn't nitrous thing type deal.
Do what he said but when your on the compression stroke(felt by air pushing up through #1 cylinder spark plug hole. You should at the least use a screwdriver to sit on the top of the piston to watch. Watch the screwdriver when it stops rising up your at TDC. This will help you get closer to TDC. If you have one at your disposal a dial indicator will get even closer to TDC but is really not needed.
Then just do like he said align the rotor with the #1 spark plug tower on the cap and install. Fire up the car and correct the timing with a timing light.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 02-05-2005, 05:45 PM
thanks alot, i was putting in a new dis and taking off the old air intake. witch is the 1st cylinder
Old 02-05-2005, 09:39 PM
Re: Re: new dis question
passenger side, closest to the radiator is #1
-Andy
