Old 01-29-2005, 07:38 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Replacing Sparkplugs
Today I was trying to replace the sparkplugs but I can't get any passenger side plugs out. I have heard you can apply penetrating oil or silicone spray... do you know if this actually works. And would any automotive store carry either of these? Thanks
White 07 STI, Bone stock for now
Old 01-29-2005, 08:10 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Replacing Sparkplugs
Yeah. WD40, PB Blaster, or something like a really light 3-in-1 oil should work. Just spray it on and let it sit overnight and they should come out.
Prevent it in the future by buying some high-temp anti-seize compound (usually found in the adhesive/silicone aisle at the parts store) and putting a very light coat on the threads before putting the new ones in. Its basically grease that won't melt or degrade over time, so 60k miles later, they'll screw out just as easily as they went in.
Dragging people kicking and screaming into the enlightenment.
Old 01-30-2005, 01:11 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
Sometimes torqing a bolt forward a little helps break the corrosion so you can get it out, but not to much don't wanna strip you threads.
I disregard my perceived image in the persuit of knowledge.
Old 01-30-2005, 08:25 PM
rodeee's Avatar
rodeee rodeee is offline
Angry Anti SEEZE
If it doesnt need locktite to prevent inadvertant loosening , than it must need ANTISEEZE! On the same note: most mechanical problems can be related to:
"This damn thing hasnt seen a drop of oil or grease in many years"
Old 01-31-2005, 12:10 AM
PathFinder 007 PathFinder 007 is offline
Lightbulb Re: Anti SEEZE
Just a thought. Oil is good. Letting it sit overnight is good. Some plugs have a seal and some have a beveled seat to seal the plug. In either case, the plug is not supposed to be overtorqued (tightened tighter than the spec'd call out for that plug) when installed but this could be the case. Trying to turn the plug in more to break it loose might not be a good idea if it had aready been overtorqued originally. So if you try turning it in, be very careful. Using a breaker bar and maybe even a cheater bar (a sturdy, long piece of pipe fit over the breaker bar) would be obvious to a mechanic or someone whose been around older vehicles or rusted nuts and bolts. But since you had to ask about the Wd-40 or 3 in 1 oil, I'm going to guess that maybe you are kindof new to this stuff. Not to be hurtful or anything.
Old 01-31-2005, 06:27 AM
rodeee's Avatar
Re: Anti SEEZE
To clarify what I meant by this is when installing new plugs or bolts, it is a good thing to use a smudge of anitseeze then turning the bolt or plug in thus preventing as much dissimilar metal corrosion and to keep a a small amount of lube available for loosening later on. This is why the product is recomended by aircraft airframe and engine mfgrs.
...The bald guy with the Spekled Mutt
If it aint gotta propeller or ROUND headlites,.. well I dont know if I can have it ready fer ya in the mornin... but come on by then bout noon and we'll talk pizza fer lunch...then things might be set right!
Old 01-31-2005, 06:45 AM
CraigFL's Avatar
CraigFL CraigFL is offline
Try "KROIL" .... it will seep into the smallest of openings
