Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-28-2005, 03:26 AM
pyrusane pyrusane is offline
Angry 98 Passport Won't Start
My wife's Passport won't start. This started yesterday at work, her battery terminals were caked in corrosion, I cleaned the posts and terminals and tightened them up, car started and she drove it home, today same problem, replaced the battery and terminals. When I turn the key it sounds like it is trying to turn over, and it has started a couple of times, but it only stays on for a few seconds then dies again. Most times it won't even start. Any ideas? Jumpstarting it makes no difference, battery is fully charged. And it is an automatic.
Old 01-28-2005, 05:34 AM
rodeo02 rodeo02 is offline
I would double check your ground connections & consider changing out the battery cables. I have seen older cables corrode internally & cause the concern you are having.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 01-28-2005, 07:42 AM
steveb_92rodeo steveb_92rodeo is offline
Also, you might want to check for proper spark at the spark plugs, and watch the fuel injectors as the vehicle is 'cranking'. If there is no fuel coming out of the injectors, it's a fuel delivery problem that will have to be addressed.
Many of us have gone through the fuel delivery issues, so if you see no fuel coming out (when the no-start is prevelant), post back and we can give you some suggestions.
Steve
Old 01-28-2005, 11:47 AM
Screwtape Screwtape is offline
This is what 2eye would suggest,
"once again sounds like the old EGR valve, it can cause this concern without illuminating the check engine light"
http://www.automotiveforums.com/vbul...d.php?t=154168
Old 02-02-2005, 05:17 PM
I-HATE-CHEVY I-HATE-CHEVY is offline
Send a message via AIM to I-HATE-CHEVY Send a message via Yahoo to I-HATE-CHEVY
Re: 98 Passport Won't Start
I have a 97 rodeo, did simaler things, but when I tried to start it it would just a clicking noise. If this is what you are getting, then it's the starter. Common problem on these vehicles.
If not, then read on. someone else can help.
Old 02-03-2005, 12:27 AM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
I am tyhinking something other than egr on this one
remove the ground wire on the alternator bracket clean it with a wire brush also try to clean the bracket where it mounts put it back together dont be a gorilla with the bolt that holds the ground in place for it is not very long it does screw into aluminum and will strip out easy (let us know if this helps)
Old 02-03-2005, 10:37 PM
Re: Re: 98 Passport Won't Start
Well, thanks for all of the suggetions folks. I'm not sure if I explained the problem very well, and it has since changed anyway. Now the car will start, but as soon as it starts it stalls out, literally within seconds. Tried some fuel injector cleaner and that is what got me to this point, but no better. Any ideas?
Old 02-03-2005, 10:47 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Intake manafold gasket or this:
http://www.geocities.com/endre_rl/isuzufaq.htm#faq22
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 02-04-2005, 07:54 AM
iskiuskiweski's Avatar
iskiuskiweski iskiuskiweski is offline
Send a message via Yahoo to iskiuskiweski
I was going to say maybe a bad fuel filter.
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k
Old 02-04-2005, 01:03 PM
Talking
glad to have you back 2eye!!
Old 02-05-2005, 02:15 AM
I missed everyone to stay gone oto long
sure am glad we have a Ryan is now moderator
