Old 01-27-2005, 04:34 PM
89rstbi 89rstbi is offline
Send a message via AIM to 89rstbi
ford 9 inch
what will it take to swatp out my rear end into a ford 9 inch---what kinda project am i looking at?
Old 01-27-2005, 05:01 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: ford 9 inch
I have never done this swap myself but from what I gather from this as well as other F-body sites is that its quite a pain to get it all together and that the 12 bolt is much easier with less lose as well even tho the Ford 9 is suppose to be the strongest Rear end set -up to work on our cars. How much power are you pushing tho?. From what I hear you need to have quite a beast to need a Ford 9'. I myself just used a Auburn locker when mine went but I think I am on the verge or destroying my current differential as it is.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 01-27-2005, 05:32 PM
Re: ford 9 inch
im running a 383 stroker---i need something to handle the power its gonna put out...i dont want to destroy rear ends
Old 01-27-2005, 06:09 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: ford 9 inch
Are you going to be using a radical cam?. What type of induction system do you have?. The only reason I ask cause your run of the mill 383 doesn't require a Ford 9'.
Old 01-28-2005, 08:59 PM
Dober89 Dober89 is offline
Re: ford 9 inch
Id go with a ford 8.8". Its strong as hell and quieter and also uses less power than the 9".
Theres a local guy here that builds them to bolt right into 3rd and 4th gens. I checked them out, its a slick setup.
Old 01-29-2005, 07:16 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: Re: ford 9 inch
If the guy is using used 8.8's and selling them at a decent price I would say that is an excellent option. If you notice the 87+ Stang guys never make much talk about a Ford 9" cause unless your car is making 700-800+HP or using a ring in pinion in the 4.8+'s range a modified 8.8 will handle your needs.
Most people go wit the 9" cause a new custom 8.8" will cost just as much as the 9" so why wouldn't you?
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 01-29-2005, 01:37 PM
Re: ford 9 inch
The way it goes is he cuts the tubes off the 8.8 center section and puts the gm tubes on it so it can be mounted into the car with no hassle. He then welds on a bracket for the torque arm. The ring and pinion are a heavy duty version from trucks or vans I forget. The posi and internals though are all new and he uses moser axles I think.
Old 01-30-2005, 07:33 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Why are people sooo concerned about the 5% (or so I can't remember the accual number) power loss out of a ford nine inch? you can put the rear end through hell and back and it will outlast the 12 blot by far. Not to mention the fact that you won't need to run C-clip elimanators.
I have put a ford nine inch rearend in a 1989 Turbo Trans Am(same rearend setup.) If you buy the moser nine inch that is setup for F-bodies, it's no different than putting in a 12 bolt/stock rearend. If you are trying to use one directly out of a ford vheicle, good luck.
Hypsi87
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
