Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-13-2002, 08:06 PM
liquid8 liquid8 is offline
Send a message via AIM to liquid8
jdm or usdm with turbo charger?
which one would be better. doesn't the jdm engine produce more exhaust or is just dirtier? jdm also has higher compression ratio than the usdm. isn't that bad?
Old 03-14-2002, 02:58 AM
buh_buh's Avatar
buh_buh buh_buh is offline
Send a message via ICQ to buh_buh
if you have a USDM motor, I would go with a USDM turbo, because the JDM turbo is made for the JDM motor, which may have a different compression ratio, or other specs. Its like slapping on a turbo that's made for a Prelude onto a Civic. It just won't work as well as one that's made specifically for your car.
AF Nordic Crew #3
Old 03-24-2002, 03:25 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
You want lower compression for boost and the JDM motors have high Compression whereas most USDM are lower compression which is better for boosting.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 03-24-2002, 06:01 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Just ask MatT3T4...he'll tell wats good or not for turbo charging. I know for a fact that u can have high compression motor and turbocharge it. NOTHING IS WRONG with that either. Its all about tuning and A/F ratio. Just ask him
Old 03-25-2002, 11:53 AM
super 96 accord's Avatar
super 96 accord super 96 accord is offline
It also matters how much boost you are planning on using. If you're not going to use a lot, then the stock compression will be fine for either the JDM or USDM engines. I don't think there's that big of a difference between them. That being said, I just ordered some 9:1 JE Pistons cuz I'm gonna be running about 20PSI!
Old 03-25-2002, 12:14 PM
mellowboy's Avatar
Yeh lowering the compression and have built bottom end is just to have and handle big boost. Having high compression with a lower boost and if its tuned rite then i bet u that they can be as fast as a built bottom end. IT cost less also.
Old 03-27-2002, 09:30 PM
HondaAdict's Avatar
HondaAdict HondaAdict is offline
Send a message via AIM to HondaAdict
JDM
JDM POWER!!!
Chris
1992 Honda Accord <-- Wrecked
1991 Toyota MR2 <-- New Ride
Old 03-28-2002, 11:08 PM
Civic_Addict Civic_Addict is offline
Yes you can have a relatively high compression and run a turbo. The high compression just means less boost. It doesn't necessarily mean less power though. Higher compression itself can make more power.
Old 04-08-2002, 01:07 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Re: jdm or usdm with turbo charger?
IT does not matter if you have a JDM or USDM Engine the Comp Ratio can always be changed on any motor. Get whatever you want. If you want JDM because that is the style you are going for then get a JDM motor but if you don't care and you want USDM then go that way also. IT does not matter.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
JDM compatibilty with USDM crusader33x 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 12-30-2006 11:50 AM
97' Legacy GT Replaced USDM with JDM EJ25 Mounday Legacy / Liberty / Baja 0 02-21-2006 04:15 PM
jdm gsr turbo or usdm gsr turbo IcESouL Integra 4 01-21-2006 01:34 PM
jdm b18c5 with turbo? FaWk '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 03-08-2004 12:39 AM
JDM/USDM swaps Racing Rice Engineering/ Technical 20 03-07-2004 04:02 PM
