Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-23-2001, 01:23 AM
supafly supafly is offline
This is for MaximumBrian
Brian, on your list of mods its says you have the Bose system in your car, but it also says you have a JL 12W3 sub and a Kenwood 650 Watt Amp. I just want to know if you integrated the sub into the bose and how does it sound and how did you do it exactly or if you just replaced the Bose?? Ever one either says it can't be done (the integration) or they say it will sound like crap.
Thanks
Supa-Fly
Old 06-23-2001, 01:24 AM
That post also applies to anyone else who has a Bose and added subs
Old 06-26-2001, 04:59 AM
MaximumBrian's Avatar
MaximumBrian MaximumBrian is offline
Send a message via ICQ to MaximumBrian Send a message via AIM to MaximumBrian
Hey, sorry about the delay it seems AF has been down a while. Well the way to do it is to purchase a high/low converter for a sub. Make sure you max the voltage out on the converter. Then, you wire the converter up to the amp on one of the rear speakers (BOSE system runs individual amps on each speaker). Then you run the other end of the converter into the stereo inputs on the amp. You wire the remote, power, and ground up like any normal system, and there you go. The reason you can't do the install conventionally is because the gain on the speaker wire coming out of the headunit doesn't have enough juice for the amp to interpret because the signal hasn't been amplified yet. The high/low converter will cost $30-$80 depending on brand and quality. Mine is one of the cheaper ones.
Hope this helps.
July 2001 Maxima of the Month
1997 Nissan Maxima SE 5Spd - Sage Mist Green - 5Spd: Leather, Dual Power Seats, Climate Control, Bose, Moonroof
Mods: Stillen 5 Piece Aero Kit / 5Zigen GT8 17" Rims / Nitto NT555 ZR-W 235/45/17 Tires / Suspension Techniques Modified Springs / Tokico Blues / Stillen Front Strut Tower Bar / Stillen Rear Sway Bar / Greddy Catback Exhaust / Cattman Y-Pipe / Random Tech 2.5" Straight Through Cat Converter / PR Cold Air Intake Adapter / Stillen ShortRam Intake with Velocity Stack / GForce 96 ECU (Testing for Maximadriver.com/Cheston) / Stillen Carbon Fiber Dash / Clear'd Amber Out of Taillights / Courtesy Front Clear Corners / SS Brake Lines / Porterfield Pads / Cut Shift Handle / Autolite Titanium Spark Plugs / B&M Carbon Fiber Shift Knob / Razo Carbon Fiber Pedals / JL 12W3 12" / Kenwood 650 Watt Amp / Redline MTF / Mobil 1 5w30 every 2500 miles / Wax every 3 months
180 FWHP - 186 TQ [Before Cat & ECU] (Outside 90F, one small worthless fan) / Estimate Power (w/ Cat & ECU) 190 FWHP - 200 TQ / 14.7 @ 94 [Before Cat & ECU] (Pomona 01/2001 - Cool/Overcast day)
http://www.brianv.net
Who wants some???
Support my business so I can mod my Maxima - http://www.vsdev.com
got this for myself for my birthday hahaha stairweitoheaven Car Modeling 12 12-31-2006 12:25 AM
Got this for my Bro for X-Mas... 1viadrft RX-7 4 12-13-2005 12:59 AM
How's this for a wing? Spunkymonkey Asia/Pacific 8 12-22-2001 03:14 AM
How bad is this for my car...? SilverY2KCivic Engineering/ Technical 7 12-13-2001 03:51 AM
How's this for a little G20.net advertising? b-b00gie Cosmetics 20 08-04-2001 04:02 AM
