Old 03-13-2002, 04:53 PM
1995HondaCivic's Avatar
1995HondaCivic 1995HondaCivic is offline
Send a message via AIM to 1995HondaCivic
17"s Rub!?
i tried to put two sets of 17" rims on my car, both which came off of a civic, and neither set fit properly. i even raised my car up and they still rubbed? is it normal for them to rub the first few days?
Old 03-13-2002, 04:55 PM
RedY2KCivic RedY2KCivic is offline
When I got my 17's I had to raise my car 1/2 an inch because they rubbed in the front.
Now they just rub in the front when I make sharp turns/u-turns/etc.
I just have to make wider turns now. all it is rubbing against is the lining in the wheel well (for me at least)
Where are yours rubbing?
Lady PH member since June 2000
Proud Member AF Cali Crew --
Nor Cal Chapter
Old 03-13-2002, 04:59 PM
i really dont know, but the back like rubs against the metal lip. could that be cut out?
b16a2si's Avatar
b16a2si b16a2si is offline
Re: 17"s Rub!?
How much is your car lowered? I'm assuming you have coilovers?
Old 03-13-2002, 05:01 PM
wow
that's not good
Like on the fender well?
Is the wheel leaning outwards? (like if you put too many washers to fix the camber)
See mine's only rubbing in the front against the lining
Nor Cal Chapter
Old 03-13-2002, 06:47 PM
changedagame108 changedagame108 is offline
Re: Re: 17"s Rub!?
Yea, how much is it lowered? If it's slammed 2.5+ inches, then maybe that's the problem. Also, what's the profile of the tire?
Old 03-13-2002, 08:10 PM
CivicEx95's Avatar
CivicEx95 CivicEx95 is offline
Banned
Send a message via ICQ to CivicEx95 Send a message via AIM to CivicEx95
If its rubbing in the rear, you can cut the lip off, thats what I did to solve the rear. As for the front, I did all sorts of stuff for my 16s with no rubbing. But as soon as I fixed the camber, rubbing caused the tire to blow. So I said fuck it and went to 15s. No problems now.
Old 03-13-2002, 09:08 PM
Re: Re: Re: 17"s Rub!?
205/40/17
Old 03-13-2002, 09:17 PM
How much did you lower your car? You may need to raise it 1/2 an inch.
Old 03-14-2002, 08:29 PM
i raised the back all the way up with the coilovers. ill have to try it again sometime. the rear lip may need to be cut out.
90 4runner rubbing noise? sickboy13 4Runner/GX470 1 01-01-2010 11:30 PM
17" Rims 245/65 tires rub when turning entine Econoline 0 04-28-2006 04:23 PM
17" rims on a hatcback, will they rub? Soldier456 '88 - '91 Civic | CRX | Wagon | Shuttlee 13 02-10-2005 02:15 PM
17" wheels rub? Stedman05 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 06-07-2004 06:50 PM
Front Fender Rub a Rub Rub genedog Tires and Wheels 1 04-13-2004 01:32 AM
