| Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here. |
Just Say N20!
Ok well as my signature shares, I dont currently have any money, and although I would kill for a turbo project on my car, it is not going to happen. Car nut or not, I am 17. A Camaro SS around here supposably runs high 11s, with exhaust, larger rear wheels and spray. From what I hear, other then internals, none of it cost him much.
I was looking at nitrous for an Alternative. For like $500 I can get a kit that is like 100-250hp. Id obviously have to spray 100 until some internal work is done, but that seems like alot of bang for the buck. A guy on a local forum, said he would sell my forged internals (unused) from his shop for around $800 (if he hasnt sold them yet ~ been awhile). So that could be the next step. What do you guys say? Yes, no maybe so? And what shot is safe on a stang? (4.6l '99). I heard 100 is safe, 150 is pushing it... |
Re: Just Say N20!
Make sure to get colder plugs(your burn out the stock ones),a 190lph or a 255lph fuel pump(your going to need more fuel pressure),use 93 octane gas and decrease your timing(so you won't ping.) If your not pinging and not running lean with a 100 shot then try a bigger shot.You should be able to run a 125 or 150 shot though. BTW are you getting a dry or a wet kit? If your going dry you may need to get bigger injectors. |
Re: Re: Just Say N20!
Re: Just Say N20!
After reading some sites out there, it seems there are people that go both ways. However, almost every "accident" I saw, involved a dry, kinda making me lean towards wet...
Re: Just Say N20!
dude just to let you know, wet nitrous systems are usually alot more exspensive because they mix with the fuel before it enters the combustion chamber. My adivce if you on a budget, get a 100-150 hp N2O application and build your engine up around that
the nitrous will give you the added power until you have the funds to truly bring your stang into the camaro ass kicking cataegory
91' Caprice Classic 145k, 305 v8 700r4 custom dual exhaust ran through american thunders dumped 92 Mustang built 302, air gap intake, 650 edlebrock carb, 1.7 rr, full msd ignition, full race fuel system, built C6 with b&m shifter and 3000 stall bbk shorties-mac o/r h pipe through cherrybombs dumped striped interior --FOR SALE-- |
Re: Re: Re: Just Say N20!
Since your going to build your engine and plan to run a bigger shot in the future then go with a wet kit.A common problem/accident that people have with a wet kit is puddling in the intake but you shouldn't have a problem with that unless you spray at too low a rpm. If your running safe on the dyno and theres no pinging then you'll be fine.Remember it's better to run a bit on the rich side then to run a bit on the lean side. |
Re: Just Say N20!
Highrev, I'm not for or against nitrous, but unlike other power adders, it comes with a never ending payment. Just something to consider for the long-run. Make a spreadsheet and weigh the long term costs of the refills against the larger up-front costs of turbos or blowers (we're talking on-demand power adders, not high power n/a engines, so let's not add that possibility in yet). Just something to consider.
Re: Just Say N20!
Don't. What do you got? $500? Go for some gears or something to hold you over until you come into some more money. I couldn't imagine a turbo'd/nitrous 4.6. Sounds like an expensive timebomb to me.
Like I said earlier, I would kill to have a turbo setup in my car. Especially because a guy on a local forum (same one offering me the forged internals) told me he would work with me to help me get turbo'd, such as building the kit for me for closer to 3k, as opposed to the kits he sells which are mostly like 5k. But with 76k on the odometer, and not much bank, it seems ill have to let that idea die. |
I'm in a somewhat similiar situation, I'm going to run spray on a basically stock 302 no higher than 150HP shot. Just enough to make myself competitve and better times at the track while I keep sinking money into my 351WTT project.
Spray is great at the intial $500-600 price tag. Then you'll want to get the most out of it so you'll have a nitrous pressure guage, fuel pressure guage for safety, and a purge and bottle blanket over time. So now your in to almost $700-$1,000. Plus depending how much you use it your paying $40 a whack to fill that 10lbs bottle which doesn't last long! I still find the example above fairly cost effective but building a motor set-up for large shots of nitrous is horrible idea on a street car. It's only enjoyable if your a track junky or it's a track car. Imagine a low CR blower/turbo motor but w/o they S/C or turbo on it. It will be a real dog anytime your not spraying and they money you spent as the shot gets larger starts equaling a S/C or turbo set-up especially when you add in your going through the 10lbs bottles at $40 a whack even faster!
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
Re: Just Say N20!
Well thats a good example. Makes you look at the building side different. Will a 150 shot damage the engine on a 4.6?
Re: Just Say N20!
my friend runs a 150 wet shot in his 2001 4.6 and he hasnt had a problem since he switched...he ran a dry shot and blew his motor running a 125 shot. the only mods he has is NOS and a 3.73 gear and he runs mid-low 8's in and 1/8 mile track
Re: Just Say N20!
I'd never put nitrous on my car. I've seen way too many people invest all kinds of money into a really bad ass car and decide they want just a little bit more and they go for nitrous and they blow the whole fucking motor to bits.
Re: Just Say N20!
well i wouldnt do it if i had a supercharger or turbo ... but on a stock motor it wont hurt if you dont over do it
