Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 01-13-2005, 06:46 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Question yellow cd deck wire
this wire is basicly my memory wire but my memory wont save ebcause i guess it doesnt have constant power or some thing. so can someoen tel lme what to do to make it work. even if i have to run awire soem were.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 01-13-2005, 07:22 PM
riccimangan riccimangan is offline
Re: yellow cd deck wire
cut it and lead it straight to the battery.,.,.,, or else take everything apart and find out where the problem is.,.,.,.,.,
Old 01-13-2005, 07:33 PM
CocaColaEatsPie CocaColaEatsPie is offline
Send a message via AIM to CocaColaEatsPie Send a message via Yahoo to CocaColaEatsPie
Re: Re: yellow cd deck wire
That will work but you HAVE to fuse that wire. just go to discount auto parts and get a fuse holder and solder it on. If you don't fuse it you may very easily ruin your deck.
John 3:3
Jesus answered and said to him, "Truly, truly, I say to you, unless one is born again he cannot see the kingdom of God."
Old 01-13-2005, 09:37 PM
ahh well il ljsut wait till i get my fused block and run it on one of the 8 channels.
06 cbr 600 f4i
91 civic hatchback.
Old 01-13-2005, 09:51 PM
bingisSD's Avatar
bingisSD bingisSD is offline
Send a message via AIM to bingisSD
you should buy the 'car to deck' adapter for your car, then the yellow runs off the radio fuse under the dash. its pretty simple. why are you having to rewire it instead of using the stock harness. hell i ran a 6.5 inch in dash monitor off of the stock harness? apparently you are running both your ACC (ignition) and constant power wires to the same wire. otherwise just replace the radio fuse underneath the steering column
www.cardomain.com/id/bingissd
http://www.automotiveforums.com/vbulletin/showthread.php?p=2660831#post2660831 <MEET IN DAYGO
Old 01-14-2005, 05:20 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Same problem happened in my friends car, we just F the trouble shooting and ran a new wire with an inline fuse.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 01-28-2005, 10:26 AM
94hondaacc 94hondaacc is offline
You Have To Change The Fuse Under The Hood. Hondas Have Two Fuses For The Radio One The The Yellow Memory Wire And One For The Ignition Switch Which Is Usually Red. The Yellow Wire Has A Fuse Which Is Under The Hood, And The Red Has A Fuse Inside The Car On The Drivers Side. Hope This Helps, Good Luck.
Old 02-02-2005, 07:05 AM
midrange midrange is offline
Send a message via MSN to midrange
well every car should have a constant power in there stock wires for old stereo. If you can't fine it, why bother going right to your battery when your fuse box is under the dash.. just get your power from there. Make sure your memory wire is on the correct wire of your car because there should be a constant power somewhere in there
