Old 01-11-2005, 01:57 PM
koreanspeed koreanspeed is offline
ticking
my engin is making a ticking noise or nocking noise, if i rev the engine it the noise goes faster, any idea of wut it could b and if it can b fixed, i think its a ummm the thing that goes up and down in the ingine, cylender? lol, well i think its 1 of them, i hope its not tho cuz that would b expensive
-[I belong in tard farm]-
Old 01-11-2005, 02:14 PM
RandomTask's Avatar
RandomTask RandomTask is offline
Banned
Re: ticking
Your description is vague, but I'll try to be specific as possible. If the ticking sounds like your tapping your fingernail on a table, this is generally the valve train of the motor. Either the tolerances have worked themselves loose (unlikely) or its being deprived of lubrication/oil (more likely). A lot of times changing the oil and oil filter can help (not completely fix) this situation and quiet the noise. Also, not reving the motor high will elongate the life of engine. There are several things you want to check if you have this noise. 1. Oil pressure. General rule of thumb is you want at least 10psi of pressure for every 1k RPM the motor is turning, hence, 4,000rpm, 40psi of pressure. 2. Like I said, how old is the oil? Try switching to a different weight, 20W-50 should help. 3. Valve Lash, the spacing between the rocker and the valve/lifters.
Sometimes on older engines, the oil pickup gets too much debris stuck in the screen and can't suck enough oil to create pressure.
If the sound is more like banging on metal with a hammer, this is generally the bottom end of a motor. Usually its a connecting rod saying "Hey, I want out of here"... This type of knock is catastrophic, the only way to remedy the situation is to tear down the motor and rebuild. Hope this helps
Old 01-11-2005, 03:20 PM
Re: ticking
thanx, ya i think i need 2 change the oil
Old 02-22-2005, 10:31 PM
MIKE21STRONG MIKE21STRONG is offline
Re: ticking
Put Some Smoke Be Gone In Your Car If That Dont Work It Could Be Your Main Bareines
Old 02-23-2005, 04:54 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: ticking
Random Task... You always beat me. Perfect response and a wonderfully accurate description. I agree 100%.
Koreanspeed... when was the last time you changed oil? What is the vehilce? How many miles on it? Some vehicles have solid lifters/followers with the cam. They require periodic adjustment from wear, tolerance, and heat cycling.
Dragging people kicking and screaming into the enlightenment.
Old 02-23-2005, 07:48 PM
deadBird's Avatar
deadBird deadBird is offline
Re: ticking
Yeah I have a constant clicking noise in my engine too. Like if you hit 2 nails together or something. What could this be? Valve springs? Someone told me it was the fuel injector mis-firing.
Old 02-24-2005, 12:51 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: ticking
Lifters
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 02-24-2005, 06:47 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
If this is a light ticking noise it could be the oil. However, give your belts a look and see if they are cracked. Sometimes a cracked belt can make a light ticking noise and since it is driving the accessories the noise would be RPM dependant.
Old 02-24-2005, 06:50 PM
deadBird's Avatar
Re: ticking
Nah I just replaced the serpentine belt less than a year ago. Besides it really sounds like it could be coming from the top left of the manifold.
Anyone have more info on lifters?
Old 02-24-2005, 07:16 PM
Schister66's Avatar
AF -Advisor
Re: ticking
as the oil breaks down, there is no lubrication on the lifters since the clearance is usually less than 2 thousandths. They stick and will start to tick. If you have hydraulic lifters, this could mean that the valves need to be adjusted since the lifter can only compress so far. Is in an SOHC engine? Post back w/ more info
Old 02-24-2005, 07:18 PM
Schister66's Avatar
AF -Advisor
if its an SOHC engine, you could fix it really easily. All you have to do is find which one is sticking and take off the valve cover, remove the rocker arms and pull the lifter out and replace it. It isn't hard on my car....i don't know about all cars though.
Old 02-24-2005, 09:56 PM
deadBird's Avatar
Re: ticking
96 2.2L cavalier. Err... SOHC?
Know of any engine diagrams that show all the parts of engine internals?
