Old 03-09-2002, 08:23 PM
CivSiGuy's Avatar
CivSiGuy CivSiGuy is offline
Banned
Send a message via AIM to CivSiGuy
*Review* DC Sports 4-1 header
Me and about 7 of my friends, including Rick (i like naked girls) just finished installing my new DC Sports 4-1 header.
Install took 2 hrs total.
Tools you will need: 10mm socket, 12mm socket, 17mm socket, phillips screwdriver, metal pipe, a pit where available
First thing to do is remove the headshield which is fairly self explanitory.
Next, loosen all of the bolts off of your head.
After that, unsnap your exhaust sensor about 6 inches up from the sensor itself, there should be a clip there.
Unbolt the header from a bracket on the lower part of the block. (That required the metal pipe after Rick swung on it for a while)
Unbolt the 2 bolts that support the header near the cat.
Unbolt the 2 bolts that hold it onto the cat itself.
Be careful and pull it off.
Unbolt the sensor from the stock header, and also twist off the donut ring and keep the stock gasket.
New header slides right in and after about 3 minutes of wiggling is ready to bolt. Bolt it up so everything is snug, wipe the header down w/ mild detergent so that all oil is off of it, and start the car and listen for leaks.
Last but not least, put your dipstick back in. Mine is still in my friends garage. A rubberbanded rag works fine in the meantime.
[img]http://communities.msn.com/_Secure/0LADqBBYP5EpYld82TDRATI6Ru*szFuYnYPghtgGGhODkg2sHc 2SslG8kB!w4rVqI3ocgwF8FDpo/header1.jpg[/img]
The gain at midrange is exactly as I expected. No more slow crawl from 5500-6500 (B16 people know what I'm talking about). It revs like its in neutral when it gets in that range. Excellent powergain, really worth the $296 shipped from www.groupbuycenter.com. (Buy from YellowTypeR, excellent pricing and service)
Here's a dyno from ClubSi.com to prove my point.
Old 03-09-2002, 08:39 PM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
well i wouldnt say i helped that much except when i was hanging in the air on the socket wrench trying to break that bolt. or giving you guys the ingenious idea of unplugging the o2 sensor and removing it once you drop the old manifold out rather then trying to take it out while the things still on the car. all in all it would have been quiker but we were bullshitting and getting the stuck bolt off was a bitch, not to mention the compression tester getting stuck in the plug hole on that quad 4....that scared the shit outa me cause i didnt think it was comin out!!!!
good times, next we gotta put some cams in, that might take about 3 days!!!
Old 03-09-2002, 08:43 PM
CivSiGuy's Avatar
Banned
Working on cars without bullshitting is like eating a sloppy joe without a napkin.
Quite a scary moment for the Quad4 I will say.
To the rest.... :finger:
Old 03-09-2002, 08:55 PM
D16 V-TEC's Avatar
D16 V-TEC D16 V-TEC is offline
Send a message via ICQ to D16 V-TEC Send a message via AIM to D16 V-TEC
Nice review, and the header looks pretty hot in there! Power gains look minimal, but torque gains look nice throughout the powerband . Does it sound any different seeing as how the engine breathes better now?
Perky Nana Boy!
I am Jack's biting sarcasm.
1990 Honda CRX Si
I poach Pandas and pimp Sheep!
Old 03-09-2002, 09:04 PM
CivSiGuy's Avatar
Banned
Yes a little bit more hiss going on.
hp gain looks small, but look at the scale of hp compared to the scale on the torque side.
It amounts to 15hp and 15lbft to the wheels at 5500rpm.
My peak torque is now moved up to 5500rpm now instead of 7000rpm now. The power is definitely there, no doubt.
Old 03-09-2002, 09:08 PM
VTEC_boi's Avatar
VTEC_boi VTEC_boi is offline
Send a message via AIM to VTEC_boi
Cool deal
You guys didn't take pics? I wanted to see Rick's lude!
"Son, your eyes look a little red there. You've been hittin the Vtec haven't you? Alright, stand on one foot, touch your nose and say 'Third Rocker Arm'".
Original PH Member (Reppin' for original PH'ers!)
www.lunspeed.com
www.jdmcivic.com
www.sweetcarz.com
Old 03-09-2002, 09:16 PM
D16 V-TEC's Avatar
I am retarded . Power gains definately look good now . I hadn't thought about the scale when I was checking it out. A hissing sound is going on? Is that normal or is that something abnormal like a gasket that isn't tight enough?
Perky Nana Boy!
1990 Honda CRX Si
Old 03-09-2002, 09:24 PM
CivSiGuy's Avatar
Banned
Originally posted by VTEC_boi
Cool deal
dude.. the pics of Ricks lude turned out pretty bad. I'll be retaking them on Tuesday when he comes back up to pick up the shirt and helms manual he left in the garage.
Old 03-09-2002, 09:26 PM
CivSiGuy's Avatar
Banned
Its the air flowing thru the header (thinner metal than the stock 300lb header )... and some of the noise from not having the dipstick in I'm sure.
Old 03-09-2002, 09:50 PM
Buzzr's Avatar
Buzzr Buzzr is offline
Send a message via ICQ to Buzzr
how come they aren't shiny like this
Old 03-09-2002, 10:18 PM
igo4bmx's Avatar
igo4bmx igo4bmx is offline
Banned
Send a message via AIM to igo4bmx
they look like the ceramic model? am i right?
Old 03-10-2002, 12:04 AM
Buzzr's Avatar
wouldn't know
are yours stainless steel or ceramic civicsi?
they look ceramic
Old 03-10-2002, 12:22 AM
ric's Avatar
ric ric is offline
ceramic
Old 03-10-2002, 01:03 AM
JayFidizzy's Avatar
JayFidizzy JayFidizzy is offline
Banned
Send a message via AIM to JayFidizzy
not a bad job at all guys......thats going to be next upgrade.....so do you have a full exhaust system or just a muffler? and which would you recommend.
Old 03-10-2002, 02:35 PM
VTEC_boi's Avatar
Arggh..ok ok ok...make sure go get a good pic of his N1. ANd, what was he doing taking off his shirt in your garage?
He has a full 2000 Civic Si exhuast
www.lunspeed.com
www.jdmcivic.com
www.sweetcarz.com
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
