Old 01-07-2005, 03:12 PM
Engine Pully Belt(s) Alternative. Ideas?
I know many of you have the same problem; the plastic pulley belts that are molded to the pulleys don’t look very good. I can fabricate my own pulleys, but having trouble with recreating the belt. I've tried styrene strip, but that has been quite unsuccessful. I've seen cool aftermarket kits, but they're a bit pricey. Can anyone share a cheap alternative?
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 01-07-2005, 03:27 PM
mrceej mrceej is offline
Re: Engine Pully Belt(s) Alternative. Ideas?
i was going to suggest the thin styrene strip. i'm planning on that for the belts and pulleys on my corolla project.
Old 01-07-2005, 03:39 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
I use the scrpas form one of the b;ack vynil roof kits, however a thin strip of masking tape painted black works well.
Someone on the SA bord suggested using an Archery Product called Spider Legs
heres the thread
http://www.scaleautomag.com/sca/comm...TOPIC_ID=10490
Freakin' Groovin"
Old 01-07-2005, 03:56 PM
spitfire143 spitfire143 is offline
for a non ribbed belt, use masking tape painted black
Old 01-07-2005, 04:01 PM
dag65's Avatar
Re: Re: Engine Pully Belt(s) Alternative. Ideas?
Gee thanks for repeating what I just posted
Freakin' Groovin"
Old 01-07-2005, 04:18 PM
Thanks for the help!
AF MODELING FAQ
Old 01-07-2005, 05:07 PM
primera man's Avatar
"P-Man"
Use very tiny rubber bands sprayed black...very easy to use and look good
View All My Models Here.
Old 01-07-2005, 05:10 PM
dag65's Avatar
Someone esle mentioned those, said they found them at Office Max I think
Arrowhead Aluminum makes some real cool turned ones with belt as well as some nice one for blown V-8s and stuff
http://www.arrowheadaluminum.com/Pulleys.html
Freakin' Groovin"
Old 01-07-2005, 06:11 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
I'll swear by the masking tape method. Cheapest detail you could add! I cut very thin strips, then I run them through the pulleys and for an added but of realism, I paint the top of the belt black and the tooth side black with a touch of rust.
Old 01-07-2005, 08:42 PM
the dog the dog is offline
Go to an Art store and get Chart Tape, made by Letra-set. Comes in several sizes, and in black.
Randy
Old 01-07-2005, 11:58 PM
99civichic's Avatar
99civichic 99civichic is offline
Send a message via AIM to 99civichic
Black electric (vinyl) tape cut in strips....
I actually used embroidery thread on the 90 Mustang I built, it was easy to use but didn't look as good as I wanted it to.
Old 01-08-2005, 01:23 AM
spidereddie's Avatar
spidereddie spidereddie is offline
Send a message via AIM to spidereddie Send a message via Yahoo to spidereddie
electric tape is what i use, if it's too shiny for your taste, then dull coat it.
Ed-
Old 01-09-2005, 12:06 PM
windsordeluxe windsordeluxe is offline
I have used black baloons cut into thin strips (the "over the hill" baloons are usually a good source) Depending on where you get your strip of rubber you get different lengths, so you can slip it over the pulleys without splicing 2 ends together.
Old 01-09-2005, 10:36 PM
008's Avatar
008 008 is offline
I use plain old printer paper painted with a sharpie. Looks good enough for me, but probably not thick enough for a v-belt setup.
-Ron
Old 01-10-2005, 12:17 AM
rsxse240 rsxse240 is offline
I am working on a tutorial that will bring you through the steps of detailing the kit supplied belts to look very real and have some chrome pullies as a side effect. I hope no one has done it before, I wanna have atleast ONE original idea!!!
