Old 01-04-2005, 02:50 PM
gotboostvr gotboostvr is offline
Send a message via AIM to gotboostvr
gs==>gst?
anyone know how hard it would be to swap out the stock 420a in my gs, and drop in the 4g63 motor and fwd tranny? new motor, trany, ecu,mounts and other shit included, would the swap itself be very hard? its my only car so taking it off the streets for a month ain't a option.
"drive fast, live hard, die laughing, and leave a good looking corpse"
Old 01-04-2005, 03:03 PM
george536's Avatar
george536 george536 is offline
Re: gs==>gst?
What engine can I swap into my GS/RS ? - ashah000
The only engine that can be directly swaped is the one that is in there right now (the 420a).
You can swap a GS-T engine into the car but it would be extremely difficult and costly.
Here are the costs (from 2gnt)
1. 4G63 turbo engine (stock) $1500
2. transmission (stock GS-T FWD) $500
3. wiring harness for engine $300
4. 4G63 ECU (stock) $300
5. shift linkage $200
6. custom engine mounts $200
7. chassis cross member $100
8. complete exhaust $200
9. intercooler, turbo, related parts $500
10. boost gauge/fuel filter, etc $300
11. Installation $1500
Total - $5600
You can also swap in a 2.4L from a Dodge Stratus/PT cruiser. This is easier than the GS-T swap, however it does require some custom faberication. Also it would be backwards (the header would be on the firewall side)
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 01-04-2005, 04:45 PM
ohh psha... im doing the instal myself. if i can find a front clip i should be set. theres no way im gonna go out and buy all the seprate little pices by themselves. im not that orginized. thoughts? suggestions?
Old 01-04-2005, 05:13 PM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Something new is coming...
Old 01-04-2005, 05:14 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: gs==>gst?
if you do the whole front end that requires cutting and rewelding the front frame forks. you better take some damm good measurements and line it up straight otherwise your gonna be cutting it off and trying again.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-04-2005, 05:16 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: gs==>gst?
doing it your self? how else would you do it? the dealer wont do it......
well your going to have to buy all the parts your self...
and next time PLEASE READ ALL THE STICKYS AT THE TOP and do a SEARCH before you post...thanks
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 01-05-2005, 02:09 AM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Re: gs==>gst?
SEARCH....all these noods need to learn.
Pictures of the Truck
Old 01-05-2005, 01:50 PM
well lets see, when i said i wasnt going to go out and buy all those little parts, i meant seperatley. front clip *bam* everything i need. and if i didnt want to do it myself theres alot of shops that would do it. no sh*t a dealer wont do that? really? sorry bout the not searching, thats a legit gripe. i skimmed over some of the topics and didnt see what i was looking for. my bad
Old 01-05-2005, 02:24 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
http://www.automotiveforums.com/vbul...d.php?t=200222 here ya go
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 01-05-2005, 02:44 PM
CBURKE's Avatar
CBURKE CBURKE is offline
Re: gs==>gst?
man you guys are to damn strick here, if you don't like the ? don't answer them. this is the only forums that is like this about what is posted. who realy gives a shit what someone posted or if they did search first, DAMN!!!
don't answer if you don't like the ???????? not that hard.
Old 01-05-2005, 03:10 PM
firesdoom's Avatar
firesdoom firesdoom is offline
Send a message via AIM to firesdoom Send a message via Yahoo to firesdoom
I don't think it's strict at all. The first reply was a cut and paste from a thread I have read many times before. My post count is very low because I spend most of my time reading all the stuff stickied and all the cool write ups and stuff. Plus you don't have to wait!
Oh yeah, the subject of this thread is misleading and also very noob-like as that question is a dead beaten horse as well.
Black 92(6 bolt) Eclipse Auto N/T 2.0
K & N Air Filter, Megan Racing Strut Bars, 2.25 Mandrel Bent Catback, Unorthodox crank pulley, EGR block off plate, No balance shafts, KYB AGX struts and shocks, two piston GSX calipers
1990 AWD Astro Van
Don't mod a car with problems. Don't swap parts without testing them.
Old 01-05-2005, 03:40 PM
CBURKE's Avatar
Re: gs==>gst?
I got ya......
Old 01-05-2005, 03:42 PM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
Re: gs==>gst?
It is strick and a lil negative for the guys who cant type very well dont you think "omg you spelled a word wrong" let treat you like an asshole. that kind of stuff ive seen alot of around here
Old 01-05-2005, 05:10 PM
95talonsb1986 95talonsb1986 is offline
Send a message via AIM to 95talonsb1986
i had a 95 talon with 420a in it and did a jdm 4g64 swap ..It is a hassle but when its done i guess its worthe it lol.. If i could do it again i would just buy a a gsx or gs-t .But if u want to do the swap u have to buy the engine, tranny, ecu and butt load of crap then you have to tweek some engine mounts and stuff lol.. .. not worth it . Just buy engine tranny and rebuild them while driving your gs and then buy a rolling chassis and there ya go ...
Old 01-06-2005, 03:51 PM
clipsekid99, thanks for that link. much apperciated
