Old 03-07-2002, 08:55 AM
zerobubble zerobubble is offline
Question 97 Civic Ex auto tranny to manual swap
Is it even possible to switch from an automatic to a manual transmision when swapping engines? Does any one know if the tranny mounts are the same and if any thing else needs to be done?
Old 03-07-2002, 11:18 AM
iroibeirt iroibeirt is offline
Send a message via AIM to iroibeirt
more work than u think
mmm its a lot more work and cost than just takin out and old engine and tran and putting in a new one.... spending a lot of time at vertex, it seems to me that most engines when bought from factories come with corresponding gear boxes and trannies....that boosts the cost up to about 5000 not including installation....and ...yes it is possible
Old 03-07-2002, 01:00 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
huh? I assume we're talking about switching between trannies that are both options (from the factory) for the same vehicle? The only extra difficulties that come to my mind immediately:
* you'd need to replace your flex plate (auto) with a flywheel
* you'd need to put in the clutch actuation system (pedal, hydraulics/cables, etc)
* you'd need to buy a clutch kit (disc, bearing, pressure plate)
Additional items about which I'm uncertain:
* not sure about how the mounts match up, I expect they're identical, or at least easy to convert
* not sure if the axle shafts are the same, but I'd guess that they are
* not sure what changes to the ECM/PCM wiring would need to be made, if any.
As far as cost goes, these manual trannies seem to go for a couple hundred bucks on ebay...
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 03-07-2002, 01:58 PM
soul180's Avatar
soul180 soul180 is offline
i had that done, one of the mounts didn't match up on the tranny. hte surgury took about 25 hours, i got all the parts for free and $15 an hour labour....
UGSTYLES
Old 03-07-2002, 11:11 PM
tenzoracerevovii tenzoracerevovii is offline
what about swapping a manual tranny motor into an originally automatic car?........not swapping the tranny and motor.........let's say i have a 97 civic.......ex automatic.......(my future car, sitting in the driveway ready to be swapped and driven (getting my license in 6 months)) anyways.....and i want to drop in a b16, manual......would it be difficult?.......what would the procedure include?
i have type-r stickers on my bike, will it go faster?
-me
Don't you know, it's 10 hp for every sticker, 50 hp extra for every additional inch of rear spoiler behond stock height.
-obiewancoyote
Old 03-08-2002, 02:02 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
if youre swapping just the tranny it could be done under a 1000 including parts and labor.
If you putting b16 or b18 you will need regular swap parts plus
shifter/pedal assembly and all the hydraulic stuff that comes with having 3pedals.
BTW the mount that you're thinking of is a rear tranny mount which is abailable from honda dealer.
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
1994 EX Civic auto tranny swap GotTheGoods420 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 15 04-18-2004 11:58 PM
auto to manual swap mattcivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 10-22-2003 04:21 PM
Auto to Manual swap question. Prelewd Pick-Up 2 05-31-2003 01:41 PM
HELP!! auto to manual swap vernonhonda '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-05-2003 07:29 PM
auto to manual swap GScivic7 Integra 1 09-11-2002 05:09 AM
