Old 12-29-2004, 04:09 PM
Pavlo's Avatar
Pavlo Pavlo is offline
My photoshop does not work???
Well, my photoshop got all f up... (8.0 CS) When I choose specific area it does no perform anything to it when i change colors and all, everything just stays the same. I tried to lower a VW beetle all it does is lower the selected area. It would not even delet things that are selected. I am a noob at this I have had photoshop for over 3 days now. Is there a mode that I turned on or off? Please help, any responses will be appriciated.
VR6> Anything
FWD sucks for understeer? Swaybars do magic.
Old 12-29-2004, 11:51 PM
Iamcool Iamcool is offline
Re: My photoshop does not work???
New problem I get this messege "Warning: No pixel are more then 50% selected..."
I have tried everything, lowering feathering, settings all the settings... Damn this sucks, is there a way to reset the whole photoshop?
Old 12-30-2004, 03:31 AM
Ran's Avatar
Ran Ran is offline
Pavlo, you need to learn wich tools to use, this is not a problem that photoshop has, you just need to learn how to do things. Photoshop is all about experimenting and that's what you should do, experiment and learn photoshop to achive good skills.
Iamcool, this happens when you feather a selection to a number of pixels that is bigger than half of the selection radius wich means that the selection would be too featherd for you to select. In other words just don't feather too much and you'll be fine.
Ran
Please read the AF guidelines
if you haven't read them before.
Old 12-30-2004, 09:01 AM
hellochevy hellochevy is offline
I like photoshop 7.0 since thats what my school uses. Maybe it is easier also. Worth a shot.
Old 12-30-2004, 09:34 AM
BuLLDoGG's Avatar
BuLLDoGG BuLLDoGG is offline
7.0 and 8.0 are exactly the same... the only difference is some minor additions and the fact that when u click on one of the filters a window with all filters appears (which makes 8.0 more easy and convinient to use)
Old 12-30-2004, 11:18 AM
Ran's Avatar
Ran Ran is offline
Re: Re: My photoshop does not work???
And ALOT of fixed bugs.
Ran
Old 12-30-2004, 05:55 PM
Pavlo's Avatar
It works when i select bigger areas, I found a way to go around that though. Thanks for replies.
VR6> Anything
