Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-05-2002, 07:26 PM
GLE96MAX GLE96MAX is offline
Question Ecu
i have a 96 gle, and it just wont go past about 4100 rpms in overdrive(about 120-122). does the se autos die here too, or do they keep going? i could get an se ecu if i had to , to fix this problem, or get an ecu upgrade.
Old 03-05-2002, 08:43 PM
maximadan96 maximadan96 is offline
Send a message via AIM to maximadan96
my max doesn't have a speed limit i got a 96 max SE auto before i got S/C car pulled to 140 after S/C i got my car uptoo 170mph with my mechanic ecu to see speed after i pass 140 . 95-96 maxima shouldn't have a speed limiter car should pull too 140.
96 Max SE auto 20% tint
MoDs- V-1 S/C 3.48 pulley, blitz blow-off valve, apexi AFC, boost gauge, air/fuel gauge, stillen y-pipe, custom cat-back with tenzo-R muffler, custom test pipe, SMX Bodykit, VB from don in (TEXAS), Hayden trans cooler , stillen adj camber plates, tokico shocks, ground-control Coilovers, addco rsb, cattman ftsb, , Altezza Crystal Clear Taillights, clear corners, PIAA Bulbs, Kenwood excelon P-907 In-Dash Mobile Television/CD Player and playstation 2 to play DVD and games.
Old 03-05-2002, 09:00 PM
mtrai760 mtrai760 is offline
Send a message via AIM to mtrai760
Re: Ecu
Do you have any mods? Take the car out of OD, drive as close to redline as you can get, about 6300rpms, the put the car in OD, the car should continue to accelerate...
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
A hunting we will go...
The Maxima is aerodynamically limited to about 160mph tops, I think your mechanic ecu is reading wrong...
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
Old 03-05-2002, 09:04 PM
96pearl 96pearl is offline
Send a message via AIM to 96pearl Send a message via Yahoo to 96pearl
no its not a speed limiter im talkn about its a rev limiter
96 gle / pearl white / black lea. int. / 17 in shoguns / black windows/
Old 03-05-2002, 09:13 PM
i have a place racing cia, nothing else. its like it just dies at 4100 rpms, a rev limiter i think, cause everywhere i see ecu upgrades about maximas they say this will knock the rev limiter out. 3rd gear just goes a little over 120 then it shifts out and nothing more. my friends se doesnt do that
Old 03-05-2002, 09:24 PM
GLE's and SE's dont have a speed limiter. You have to get 4th gear far enough into the RPM range that it makes enough power to pass 120. 4th gear in auto max's is really tall, so the engine has to work really hard to keep accelerating against wind drag at that speed.
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
Old 03-05-2002, 09:55 PM
it sounds like its gonna blow up with the cai on it at that high of rpms. so your saying redline it before OD
Old 03-05-2002, 09:57 PM
then again there was one night me and my girlfriend and two others were in my car and i got it two 125 ish range. wierd i guess
Old 03-06-2002, 12:07 PM
Don't redline it, but get it to just before redline, about 63-6400 rpms, then turn the overdrive on...
I also wouldn't be trying this with other people in the car, but maybe thats just me...
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
Old 03-06-2002, 10:44 PM
that was just once, i dont do it often. well i did what you said and it gets up pretty good now, got it to like 127 then had to let out cause of cars in the way.
ecu ecu ecu i see you MODIFIED_GSR Integra 7 05-04-2005 10:31 PM
converting ecu plugs to OBD-1 ???? p08 ecu install SIvic '88 - '91 Civic | CRX | Wagon | Shuttlee 2 03-21-2003 01:28 PM
88 ls ecu vs 89 ls ecu outofstep '71-'87 Civic | CRX 5 04-13-2002 02:41 PM
99 G20 ECU vs 98 Primera ECU bafo Engine 2 01-29-2002 02:29 PM
