Old 12-23-2004, 04:03 PM
i6oR i6oR is offline
Negative camber
is it posible for u do do a negative camber to a car is so how is it done ? thank you, BTW i have gone to SEARCH all ready and found nothing
Mi CaR
Old 12-23-2004, 04:06 PM
lilbudman's Avatar
lilbudman lilbudman is offline
Send a message via AIM to lilbudman
I've never had any luck with it, what kind of model are you doing?
Lil'budman
Thanks to me for learning how to make my own God damn sigs!!! J/k If anyone needs a sig PM me.
Old 12-23-2004, 04:37 PM
ATMDC's Avatar
ATMDC ATMDC is offline
Re: Negative camber
well ive never tried it, but this is just an idea, if you have a car that doesnt have an axel that goes all the way across, and its the kind where each wheel has its own bearing to roll sort of say, i guess you could heat the suspension arm a little bit and kinda bend it upward or downwards to kinda tilt the wheel a little, if you know what i mean
Old 12-23-2004, 04:39 PM
it is a revell integra type R
Mi CaR
Old 12-23-2004, 04:57 PM
ATMDC's Avatar
Re: Negative camber
yea that has the kind of suspension im talking about, but dont try it until you have thought all of the possibilities, get others opinions first
Old 12-23-2004, 06:13 PM
Lownslow's Avatar
Lownslow Lownslow is offline
Re: Negative camber
i usually add a .5 shim on the wheel or carefully bend the locator pins
Old 12-23-2004, 06:15 PM
i mean its my first tune so i dont wana ruin it
Mi CaR
Old 12-23-2004, 10:25 PM
Camber's Avatar
Camber Camber is offline
Send a message via AIM to Camber Send a message via Yahoo to Camber
Re: Negative camber
*Edit*.. sorry I thought I was in the Diecast forum.
Old 12-24-2004, 01:41 PM
rsxse240 rsxse240 is offline
Re: Negative camber
I would just shim it, but if you are slamming it too, then it is alot more involved than that. do some research, go to some real car forums and see how it is done in real life and modify your kit accordingly.
Old 12-25-2004, 01:36 AM
El Krammito's Avatar
El Krammito El Krammito is offline
Send a message via MSN to El Krammito
on both my ae86's the front screws were slightly loose since i used wheels other than fujimi. that made it easy for me to have camber on the front wheels.
The Krammit
