Old 03-05-2002, 11:24 AM
Hawk312 Hawk312 is offline
Noone can have a yellow finish! or Tamiya Yellow spray never again...
Well, I just got finished emptying the FOURTH can of Tamiya yellow spray (TS-16) on my modena model. Needless to say I will never again use this *&^%!!! I can still see panel lines through the paint and will have to brush paint parts of the exterior because I refuse to buy anymore paint cans. Honestly, I have had much better luck with enamels, no kidding! So again, I am in the same predicament. What kind of spray to use to get a Yellow finish? Testors enamels are hard to work with, and now Tamiya has been ruled out. The auto parts stores dont carry a yellow automotive spray that I can find. The closest they have is a real pale yellow, but no true yellow. Anyone who has done a Yellow paint job, what is your secret? I have done hundreds of models, and only 2 so far have been yellow, even though it is on of my favorite colors on a sports car.
WANTED! 1/12 Corvettes and Camaros.
Newest builds. Click on images to go to the thread:
1/12th `69 Z/28 Camaro and 1/12 `67 Corvettes
Old 03-05-2002, 11:34 AM
JE123's Avatar
JE123 JE123 is offline
I've done a yellow Camaro. I used Testors yellow spray.
-Joshua
Old 03-05-2002, 01:12 PM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Funny I used that same yellow on the bottom of my Mugen ITR and it came out fine with one coat.
Old 03-05-2002, 01:14 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Buy another can of TS-16 and try again. Otherwise, you can't paint yellow no matter what kind of brand you use.
But this time, make sure you spray the undercoat after primer. The undercoat can be white for translucent colors like red or yellow. From my experience, I found tan more suitable for yellow because tan is very opaque. Make sure you thoroughly smooth the undercoat, then use TS-16, and you'll be happy that you want to hug and kiss the Tamya spray.
Hiroaki Fukuda
Old 03-05-2002, 01:29 PM
I guess I should clarify: All 4 cans of paint are still on the car! It seemes that the paint went on fine. I did the typical mist coats, only this time about 15 of them instead of the usual 3 or so! I even tried heating the paint a couple times, which usually works wonders, but no luck. It seems the paint comes out to fast. I started getting fairly decent coverage if i held the can about 2 feet away (!!!!!!!!!!!), but what a waste. The body was primed before I started, and it didn`t require sanding between coats. I used light gray primer, which I thought may be a problem, but still you would think 4 cans would cover it.
I am assuming by "undercoat" you mean spraying another color over the primer but under the exterior color?
Old 03-05-2002, 01:51 PM
awaken1973 awaken1973 is offline
Send a message via ICQ to awaken1973
Why not TS47? I used Chrome Yellow on my Porsche 911GT3 and it's NOT translucent. 3 coats quite enough to cover all model
Current project: Tamiya Porsche 959, red
Old 03-05-2002, 01:55 PM
primera man's Avatar
"P-Man"
TS-16 is a bastard colour to work with.
I would change the shade of yellow to either TS-47(Chrome Yellow) or TS-34(Camel Yellow)
View All My Models Here.
Old 03-05-2002, 03:00 PM
S Brake's Avatar
S Brake S Brake is offline
Ferrari Guy
Re: Noone can have a yellow finish! or Tamiya Yellow spray never again...
why would anyone want a yellow Ferrari????
The contents of this post may be fictitious.
Old 03-05-2002, 04:12 PM
JE123's Avatar
Re: Re: Noone can have a yellow finish! or Tamiya Yellow spray never again...
Beats the heck out of me. It has to be red.
....mmmmmmm.....red.....drools....
But it is up to you.
-Joshua
Old 03-05-2002, 07:09 PM
daggerlee's Avatar
Old 03-05-2002, 07:30 PM
Because they have a hundred million billion red ones already. :flash: :flash: :flash: :flash:
Old 03-05-2002, 08:40 PM
turbos86's Avatar
turbos86 turbos86 is offline
Originally posted by daggerlee
This is just WRONG!
Old 03-05-2002, 11:10 PM
This is just WRONG!
This is SCARY!
If you bothered from red and yellow there are lot of options for Ferrari.
I likt this blue metallic
Old 03-05-2002, 11:51 PM
hiro's Avatar
hiro hiro is offline
The blue is nice I don't like red cars much but of course Ferrari is an exception! That green thing up there is just a frog pretending to be a car.
Jenny
Old 03-06-2002, 12:08 AM
Jay! Jay! is offline
Horizontally Opposed
Ferrari uses the green cars like that F50 for testing, i.e. crash testing...
Hierarchy of Subaru:
(Click to see mine!)
Tamiya TS spray cans suicidehummer Car Modeling 7 10-23-2006 11:39 AM
How far does a can of Tamiya TS spray go? mickbench Car Modeling 18 01-19-2005 07:21 PM
Tamiya clear spray over Tamiya Matt spray? Tikiman Car Modeling 5 08-31-2004 03:54 PM
Can I use neutral grey primer with tamiya yellow? Shalin Car Modeling 4 08-06-2004 05:11 PM
