Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 12-22-2004, 08:03 AM
hardcorewings hardcorewings is offline
civic bearings
my bearings are going bad and i need to replace them. . . i was wondering if they were pressed or not. and if their a pain to replace.
Old 12-22-2004, 06:13 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: civic bearings
what bearings are you talking about?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-22-2004, 11:46 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Thats not too vague.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 12-23-2004, 01:04 AM
AF - Advisor
differntial bearings, front and rear pinion bearings, spindle hub bearings, wheel bearings, etc,etc,etc. just a few.
we'll just assume it is the wheel bearings.
Remove wheel, caliper, rotor, brake line, abs line, 32mm nut, 3 17mm nuts and then remove the hub assembly. take hub assembly to press it out of the bearing. remove c clip then press bearing out of spindle. remove inner race from hub. when bearing is out of spindle, install new bearings (press it in). install c clip. with new bearings in spindle, press hub into new bearing. installation of reversal.
to make it easier, take it to a machine shop with a press if you dont have access to one.
