Old 12-21-2004, 04:55 AM
TanKaBoY's Avatar
TanKaBoY TanKaBoY is offline
building center panel hoods for gauges??
hmmm i was wondering how u could build this?. Sometihng along the lines of this(below)
but like how would u go about making it more "rounded"?
Completed:
Sexy Iwase Kyoko's FD3S RX-7
Apexi D1 FD3S RX-7
Old 12-21-2004, 05:22 AM
sjelic's Avatar
sjelic sjelic is offline
Re: building center panel hoods for gauges??
If you ask me I would cut three pieces of sprue, glued them together, shape them at the oposit end make the bottom out of flat sheet of plastic and make housing with putty around the spru, that way you can chose how rounded you want them to be, when you are done paint and put decals for gauges ant put a drop of clear on top of decals to make it look like glass.
Sasa Jelic
SCALEMAKERS
Old 12-21-2004, 09:10 PM
weaponCIVIC's Avatar
weaponCIVIC weaponCIVIC is offline
yeah i know what you mean, that pod thing......well i would use styrene and styrene tubing cut in half to create the roundedness over the gauge. then bring it all together with tamiya putty.
http://www.automotiveforums.com/vbul...d.php?t=620111
"Look as far as the eye can see, go there, then look farther."
Old 12-21-2004, 09:21 PM
TanKaBoY's Avatar
which tamiya putty would u use?
and how thick and big should the styrene be?
Completed:
Apexi D1 FD3S RX-7
Old 12-22-2004, 01:30 AM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
Like so?
Made with evergreen tubing (small?). I choose the size to fit the MCG guage faces I had. Cut small pieces and glue them with a bit of stagger, when dry you can sand, putty or whatever to get them to fit your dash.
SCCA 7, The lost Z
Old 12-22-2004, 02:34 AM
TanKaBoY's Avatar
yea like that, but then it also has a curved hood over it.
like this:
Completed:
Apexi D1 FD3S RX-7
Old 12-22-2004, 03:41 AM
spitfire143 spitfire143 is offline
buy the revell 98 Saleen kit, comes with one
