ok i want to know if this is a good shift kit, http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
or is this one better, http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW and what does aod stand for. thanks alot. |
Re: Shift Kit help
and this is for a stick shift right.
me i would go with the transgo it has your power yet you can just cruise and not rip your neck off lol also both of these are over drive aproved thats good but check out a summit catolog i bought a shift kit for a camaro i had(i know sacroligious) and it kicked ass they give you a choice of 3 stages towing street and strip i hope that helps
Put the tools down and step away from the car!!!!
Sorry man but I think you need to do some reading and studying before you buy or even worse attempt to install something on your car. Shift kits are for automatic transmissions, AOD=automatic Over Drive. A plus is you picked the two best shift kits made for AOD's.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
Re: Shift Kit help
lol, so should i just get a shorter then, that is what i thougt, i thought it was for automatic but i was not sure. lol
Re: Re: Shift Kit help
If by shorter you mean short throw shifter than yes. But make sure you know what manual tranny you have in your car.
Re: Shift Kit help
why does it matter. how are you soppose to tell.
Re: Shift Kit help
so this car is not automatic cause shift kits are just for automatics
im not for sure but i think it resticts trans fluied flow tell the right time thats what the kick is from kinda like kinking a water hose and letting go is that right gtstang short throw is for manuel trans and it makes for faster shifting what do you want to acomplish with this |
Actually it's the opposite, a shift kit increase the flow of tranny fluid either through bigger holes, diverting it where it's need more, or different strength springs. This increases line pressure with leads to faster, firmer shifts
Re: Shift Kit help
^^^ Couldn't you achieve the same thing by programming a chip with the proper shift points, therefore negating the need for a shift kit?
(Not that it matters much to me, as I wouldn't be caught dead driving a Ford Auto Tranny LOL )
95 GT AKA "The Purple Hippo". Stock 302 bottom end. Edelbrock Heads. Performer 5.0 Intake, 1.7 RR's on stock Cam, Stock T5, 3.27 gears, UD Pullies, K&N Filter, rubber boot deleted, A/C deleted, BBK Catted X-Pipe, 180º TStat, EEC Tuner running J4J1 stock BIN. AEM WB02, Minor tunes, running pig rich. No clue as to RWHP feels a tad faster than a stock 05 GT. |
How exactly do you propose the chip controls the tranny's valve body?
Re: Shift Kit help
so how am i soppose to tell what kind of tran i have.
Re: Re: Re: Shift Kit help
The PCM controlls ALL the shifting and T/C lockup functions on the later model ATs (since the early '90s) for the AODE, 4R70W, 4R75W, 5R55, E4OD, 4R100, 5R100 etc. We are talking line pressure, T/C lock-up timing and pressures, and the solenoid activation timing (shift timing). ALL these functions are also "adaptive", they adjust for driving style and wear (within limits). There is absolutely NO NEED to purchase any form of "shit kit", the makers of these things do things to your AT that WILL kill it, and if not sooner then later. They have NO CLUE how to properly control a Ford AT, but they do a good job of messing them up. I have seen more than enough trans-go equipped ATs fail at WOT on the dyno because of what they do to the control circuits to EVER suggest they are ok to use. It really does not matter what "brand" of "shift kit", they are all IMO JUNK! If you want the REAL SCOOP on your AT, and modifying it, go to www.tccoa.com and look at their tech sections under "transmission". The articles there were written by a former Ford powertrain engineer (worked on the AODE/4R70W), and HE KNOWS exactly where the weak points are, and how to correct them. Transgo etal, DO NOT. Last edited by ModMech; 12-25-2004 at 03:44 PM. |
Re: Shift Kit help
^^^ Nice!!
I was pretty much going to say the same thing, but you've said it with 5 times more detail than I could add
-Andy '89 Mustang 5.0 - How fast? i'll know this weekend. '86 Mustang LX - Shortblock is built, now for the rest of it. "Put the subject before the verb, hmm? Fail this class, you will." -Yoda teaches english class. |
