Old 12-18-2004, 02:14 PM
joelo59's Avatar
joelo59 joelo59 is offline
Send a message via MSN to joelo59
Exclamation Help for newbie please TS cans to AB
Hello
I have a double action tamiya AB and I was trying for the first time taking out the paint of the TS spray cans to use with my AB. At first it was painting awsome, but a little later I got like little drops of paint when I pressed the trigger, and also the paint started to get textured. When I take out the paint from the spray I wait like 2 min for it to gas out. Is this to short? Do I have to wait more?. Another thing is that the paint when come out at first is very thin but after a little while it gets thicker. Do I have to use thinner because some guys dont use thinner for this method and get awsome results. Oh another detail, I had to take out some more paint out of the spray can because I ran out, then I got this little problems. Any help will be great
Old 12-18-2004, 03:38 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Help for newbie please TS cans to AB
http://www.briansmodelcars.com/tutor...ID=3&CurPage=1
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 12-18-2004, 03:49 PM
hirofkd's Avatar
hirofkd hirofkd is offline
If the paint seems to dry too fast to your taste, add a few drops of Mr. Retarder by Creos (formerly Gunze). This product is meant to deliberately slow down the drying time so that the paint lay down on the surface smoother. I know a pro who uses a mix of 50% thinner and 50% Retarder to make his own custom made thinner. You can also try Creos's Mr. Leveling Thinner, which almost has the same effect.
Hiroaki Fukuda
Old 12-18-2004, 04:55 PM
tonioseven's Avatar
Where can this Creos be purchased? I'd like to try it.
Old 12-18-2004, 07:00 PM
hirofkd's Avatar
Many places still list their products by Gunze Sangyo instead of GSI Creos. Anyway, Best1Hobby lists the Retarder, but not the big 400 ml bottle of Leveling Thinner.
http://www.best1hobby.com/html/gunze/tool.html
Hiroaki Fukuda
Old 12-18-2004, 07:20 PM
ImolaEK's Avatar
ImolaEK ImolaEK is offline
Re: Re: Help for newbie please TS cans to AB
Awesome! I have been meaning to get some Gunze Sangyo stuff as well as Finisher's paints.
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
www.myspace.com/joeham
Old 12-18-2004, 07:34 PM
freakray freakray is offline
AF Modelrater
Tonio, Scaleracecars.com carries a lot of the Gunze/Creos stuff, if there's anything special you want, just contact David and I am sure he can get it.
AF User Guidelines
Old 12-18-2004, 10:33 PM
tonioseven's Avatar
Great!! I'll contact him Monday!
Old 12-19-2004, 08:01 AM
RallyRaider's Avatar
Zomby Woof
I always let the decanted paint gass out for several hours but some people use it straight way with no problem. So long as it doesn't boil over in the cup and make a mess it should be okay.
Sounds like the paint is getting too thick. Just regular automotive lacquer thinner is okay to thin down decanted TS paints. Tamiya already have a retarder in there. At least it seems that way to me becuase the rattlecan paint always takes longer to dry than straight airbrushed lacquer.
Old 12-19-2004, 09:06 AM
ImolaEK's Avatar
Wouldn't the automotive lacquer thinner melt the plastic???I have been meaning to ask that question for a while.
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
Old 12-19-2004, 09:27 AM
360spider's Avatar
Yes, it would if used without primer.
ItalianHorses.net
Old 12-19-2004, 10:44 AM
joelo59's Avatar
Thanks for the help but I saw that my AB needle is kind of bent. I think this is the problem.
Old 12-19-2004, 03:49 PM
robrex's Avatar
robrex robrex is offline
You should pick yourself up a cheap moisture trap as well. I had the same problem and after fitting the trap haven't had any problems.
Rob
