Old 12-14-2004, 11:19 PM
solaris=amazing's Avatar
solaris=amazing solaris=amazing is offline
Question Was Fix-a-flat Used..How Can I Tell?
Today, i noticed again, that my front right tire was 2 psi less then the other three tires.
Lets say i fill all tires to 30psi, the next morning, i'll check my tires, and notice all of them are 30psi, except the front right, which will be atleast 1-2 psi less. It doesn't go less than that though, so it's really not a leak. Could someone have used fix a flat, or whatever, and it effects this?
I went over almost every inch and there is no sign of a stab, or leak etc.
Old 12-14-2004, 11:21 PM
Re: Was Fix-a-flat Used..How Can I Tell?
BTW, i don't think its the valve stem either, it's good and tight. It just drains, then stays at that, tires are funny :-(
Old 12-15-2004, 02:32 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
if you dismounted the tire you may see some residue. chances are you have a VERY small leak, and once you get down to 28 PSI it closes up.
Old 12-15-2004, 05:33 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
consider yourself lucky
Mine does the same thing, but one tire always stops at exactly 12 PSI. I get a good two days out of an inflation and then I'm dragging out the compressor.
There are a couple things you can check. Get a spray bottle of someting sudsy and spray the valve and the entire inner and outer perimeter of the tire where it meets the wheel. If its leaking at the rim, you can have it dismounted and remounted using a silicone-type sealant at the bead. That usually solves the problem.
If its the valve stem leaking, you can unscrew the valve from the stem and replace it.
My guess is that you have aluminum wheels. They corrode around the bead and tend to let tiny leaks sneak by the tire. The best cure for this is to pull the tire off and use a wire wheel on a grinder to re-smooth the sealing surface. I would also suggest using the sealant when they're re-installed to be sure.
The reason it goes so far and then quits can be demonstrated by holding your breath. If you hold your breath by closing your lips and then try to push the air out, your lips yield letting air out. They are clamped together by a certain physical strength. In your tire anything over 28 psi will overcome the seal. It leaks until its down to 28, then it quits.
Dragging people kicking and screaming into the enlightenment.
Old 12-15-2004, 03:07 PM
Very true guys, my guess is exactly what curtis says, about the leak forming around the rim. They are aluminum also. I have to check this, unfortunatly it's like 20 degrees out, so maybe i'll bring it in somewhere..
Thanks alot..
