Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 12-14-2004, 08:51 AM
stock01GrandAm stock01GrandAm is offline
Send a message via AIM to stock01GrandAm Send a message via Yahoo to stock01GrandAm
Thumbs down Stalling 96 Civic hatch
airight, i have a 96 honda civic hatch with 300,000 miles on it, that burns a lil bit of oil. On hot spring/summer/fall days after the car warms up, she will stall on me when i come to a stop. I'll push in on the clutch, come to a stop, the idle will get rough, and she will stall on me, any suggestions on how to repair this?
2001 Grand Am
1996 Honda Civic Hatch Beater
1997 Chevy S-10 Engine Rebuild
Lowered Limitz
Old 12-14-2004, 09:04 AM
cas4067 cas4067 is offline
Re: Stalling 96 Civic hatch
Well I got a 96 civic coupe with 90,000 miles and mine is starting to do that too. When I come to a stop it starts idling real low like it's about to stall but hasent yet. I am thinking it might be the pvc valve. Might have to do with the vacume lines let me know how you get your problem fixed because I will proprably have to do the same thing. Sorry for not being any help
check it out let me know what you think
my ride
Old 12-14-2004, 09:28 AM
Re: Re: Stalling 96 Civic hatch
makes a lot of sense, mine doesnt do it at all when it is cooler out, how bout yours?
2001 Grand Am
Lowered Limitz
Old 12-14-2004, 09:38 AM
BennyBakwood007 BennyBakwood007 is offline
PCV valve might be bad or your timing might be off
97 EX
What do i say to a Dead Cops wife??
Cops kill my People Everyday...thats LIFE!!!
Old 12-14-2004, 12:11 PM
honda_luvr_2000 honda_luvr_2000 is offline
could even be as simple as u'r idle needs adjusted. not saying that's it, but u could check it since it happens only after the car has warmed up. that's when the car idles the lowest. so if the idle is set too low, then it'll also cause that problem. as already mentioned, could also be a vacuum leak, PCV valve, or EGR system, etc. but those all deal w/ vacuum
Old 12-15-2004, 02:03 PM
Geeko Geeko is offline
Send a message via ICQ to Geeko
Has the Civic thrown a code from the ECU? Just after I got my '96 hatch, and drove it 1200 miles from texas, I got a dumb-dumb light on the dash and it started stalling (this is about 93k miles on the odo). I took it to the dealer and the oxygen sensor had gone bad- and it's covered under a recall, no cost to me for anything.
It's just a thought, at least. Also, make sure your gas cap is tightened down properly- these cars are positive-fuel-pressure, and if the cap is loose they can't build up proper pressure and will stall.
BD (Before Deer): Clean... Very Clean.
AD (After Deer): Nascar Ready.
Go Baby Go.
Old 12-15-2004, 05:09 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
at 300,000 miles, you may have more problems than you think. its only a matter of time, or you can do something about it now. go with the basic maintenence, if you havnt yet. if your burning oil, you need a compression and leakdown test. you sound like you busted some ringlands. your idle may be related to your oil burning at 300,000 miles. give a vacuum and oil pressure check too. these three test will help you pinpoint the problem, instead of picking out a possible problem and just fixing hoping it works. the three testing tools can easily be rented at your local autoparts store. if your not confident with performing the test, ask the clerk to do it for you outside in the parking lot (Autozone and Kragen are pretty cool with doing this, others like Napa may not), or just pick up a helms. you can also take it to a trusted auto repair shop and have them do it. this should be step one at 300,000 miles.
heres some referenc.
http://www.automotiveforums.com/vbul...d.php?t=328798
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-17-2004, 07:10 AM
Good
thanks for all the help.
2001 Grand Am
Lowered Limitz
