Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-02-2002, 07:07 PM
tha magistrate tha magistrate is offline
Cool Reseting Engine Light. How? any Links?
I put an intake in my freind's 2000 Prelude. I know you have to reset the Check Engine light because I had to to do it for my Integra, but I don't know how for a Prelude. If anyone can real quick just give me any advise or a link to a website telling me how to do it we would appreciate it. Also, we heard of this new website for parts called www.streetstyling.com They're not up yet but some of our friends heard about it. They're suppose to carry a lot of shit amd not askin a lot for it. Check them out sometime this month when they go public and we'll post again if they're dope. Thanks in advance for your help about the light.
Old 03-02-2002, 08:07 PM
BoosterSH's Avatar
BoosterSH BoosterSH is offline
Did you unplug the negative cable while you installed the intake? If not try doing it now. When you put the cable back on and your indash stereo asks for a code, you know the ECU was reset. Thats if you still got the stock dash unit.
Its what i did to my lude when i installed my CAI. Although my engine light never came on.
Old 03-03-2002, 12:31 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
pull the ECM fuse out and put it back in after 5 minutes with the car off. it's located in the fuse box in the driver's kick panel on a 5th gen Prelude.
it's easier than pulling the battery cable since you dont have to reset your stereo, clock, etc.
Old 03-05-2002, 11:02 PM
Chrislethal Chrislethal is offline
Smile
Check engine light
Hey pulling the backup fuse or disconnecting the battery good and cheap or you can also take it to the shop for them to put a scan tool and erase the code of the ECU with without pulling the plug. with OBD II the check engine light doesn't go off for certain amount of key cycles.
Old 03-10-2002, 03:44 AM
WickedSSH22a4 WickedSSH22a4 is offline
Hhmmm. The check engine light didnt come on for me when I had my intake done... Vaccum hose not loose anywhere????
Anyhow...Disconnect the battery neg cable. pull the 7.5amp fuse in the fuse block inder hood. pull the ECu fuse in drivers kick panel. leave out for 5 min... Reverse procedure. start car and let it IDLE for 5 min. No touch anything while its idling. The check eng light should not come back on unless something is wrong with emmissions system (intake included).
Its not true when the guy said the check engine light would not go off for a couple of cycles... Once you reset the ecu, it should go off...But may come back on if something is wrong....
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
grand am engine light? confuoco1 Grand AM 1 04-01-2009 04:06 PM
