| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
My accord coupe, has the engine code of f20b stamped on the vin plate. I have been looking for the compresion ratio for this engine as I am considering a supercharge conversion. I have found the f20a to have 9.5:1 is this identical ( As I obviously cannot take the ratio over 12:1 or the engine will deisel and knock). any idea if 10 psi of boost ill keep the ratio low enough???
Re: Honda F20b Supercharge??
You might have better responses if you put this in the forced induction forum.
If you want to run pump gas, you better stay waaay under 12:1. I'm considering a turbo on an 8.5:1 V8 and I can probably go about 7 psi on pump gas. That's iron heads; your aluminum heads should allow for about another half a point of compression for 9.0:1 Some of the "blown" guys hang out over here too, but if you don't get specific responses, try moving it to the other forum.
Dragging people kicking and screaming into the enlightenment. |
