Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Cosmetics
Cosmetics interior, exterior, wheels.
Old 02-28-2002, 08:24 PM
95_G20_P10's Avatar
95_G20_P10 95_G20_P10 is offline
how to hold mesh for the grille inplace????
does anyone know how i could hold some mesh for the upper grille inplace? i want cut out the black and leave the chrome triming around and put some mesh in there but i dont know how i would be able to get the mesh to stay? any ideas?
95 Pearl White :silly2:
http://members.tripod.com/g20blaze/
:coolguy:
Old 02-28-2002, 09:20 PM
Yahnozha Yahnozha is offline
Send a message via Yahoo to Yahnozha
Depending on how detailed you are cuttng the mesh, and depending on what it is made of you can do a couple of things.
If you trim the grille mesh to match exactly with the inside of the plastic all the way around you can use a two part epoxy, or JB weld, just try it out first to make sure paint will adhere to it. If it doesnt adhere, make the grille a little bit bigger and cut "slots" for the grill to poke thru the plastic and then glue there.
Or...you could weld on little tabs to screw the mesh on, pretty detailed and a lot to do, but will let you take it off if it gets damaged...Just my opinion tho...good luck
P@ - www.customsteel.com
Red 99 G20(t) / UR 2 piece / JWT POP / HS CAI / WW Lip / HS Header / Greddy Evo / S3 cams
Old 02-28-2002, 11:38 PM
95_G20_P10's Avatar
thanx for the ideas i'll have to give it some thought
:coolguy:
Old 03-01-2002, 11:31 AM
NismoG20 NismoG20 is offline
i did this with mine dude
i cut out all the black shit... took off the chrome peice... cut the mesh to fit and then glued the chrome peice back on over the mesh and it all fit together fine... so the mesh is held on by the chrome peice
Craig....
--->redline all the way baby!
Old 03-01-2002, 12:32 PM
95_G20_P10's Avatar
yeah thats what i was thikin but i wasnt sure if that chrome peice would hold the mesh on but i guess i'll give it try. Nismo got any pics of the grille
:coolguy:
Old 03-01-2002, 01:26 PM
g20jojit g20jojit is offline
Exclamation grill
hi men,once your finish modifying your grill let me know how was it ,coZ i'm planning the same thing.by the way i'm from CT. too! Thanks.
Old 03-01-2002, 01:56 PM
95_G20_P10's Avatar
Re: grill
where in CT u at??
:coolguy:
Old 03-01-2002, 02:30 PM
p_r_i_m_e_r_a's Avatar
p_r_i_m_e_r_a p_r_i_m_e_r_a is offline
Send a message via AIM to p_r_i_m_e_r_a
I always use fiberglass, when done right everything is solid. The downside is it can ge messy, and you don't want to over-spread. Otherwise overcut your mesh and use screws with some type of hook attached. Just make sure to hide all mounting points!
________D________
  • 94 P10 w/mods
  • 92 P10 stock
Old 03-01-2002, 05:02 PM
from hamden
Old 03-02-2002, 01:17 AM
95_G20_P10's Avatar
no way bro. how old r u
:coolguy:
Cars for the Cure 2009 Pictures Pastapuck Car Shows 0 02-11-2009 10:45 PM
How much longer for the E46 M3?? yoeddie M3 6 03-20-2003 02:13 PM
How much longer for the E46 M3?? yoeddie Z3 2 02-24-2003 09:07 AM
where can i get good mesh for my grill?? 95_G20_P10 Cosmetics 3 03-16-2002 01:52 PM
