Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 12-02-2004, 08:45 PM
DelSolo DelSolo is offline
Heater Probs
I have a 93 del sol and the climate controls work except it does no blow hot air, just cold air when I select the heater feature. Does anyone else has this problem or knows what the exact problem/solution is?
Old 12-03-2004, 09:35 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
hmmm maybe your thermostat is broken, but i think i could be the heater valve. When was the last time you serviced you cooling system. Hmm id say check your thermostat and you heater valve.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 12-03-2004, 10:41 AM
I just bought the car this week.
Old 12-03-2004, 08:49 PM
NA is Best!
ok, id say check the thromostat (take it out and put in in boiling water and see if it opens) and check the heater valve, it might be jammed. If you do take the therm. out then thats the best time to flush you cooling system. thats all i can think of - if your not comfortable doing that yourself, then take it to a shop.
