Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-28-2002, 10:06 AM
eric26's Avatar
eric26 eric26 is offline
Send a message via AIM to eric26
no brake power
Hey guys I have a 90 integra Gs with the b16 anyway when I try to stop I have no brake power so I have to pump the brake until it stops. It has new brake pads all around and has brake fluid and checked the brake lines.
88 ACCORD LX-i WITH XENON KIT, TOKIO SHOCKS AND SPRINGS, FUNSA RIMS 15'S,DC SPORTS UPPER TIE BAR,93 CIVIC INTAKE WITH K&N PERFORMANCE FILTER,DC Sports ceramic coated 4-2-1 headers PACESETTER HIGH PERFORMANCE EXHAUST SYSTEM AND A 1000 WATT RADIO SYSTEM.
SOON TO GET.
5 speed swap.
Old 02-28-2002, 10:30 AM
97teg 97teg is offline
sounds like the master cylinder. does the brake pedal fade when you stay on it?
Old 03-02-2002, 10:27 PM
eric26's Avatar
yes
YES, the brake pedal fade when I stay on it.
HELP WHAT CAN IT BE?
SOON TO GET.
5 speed swap.
Old 03-03-2002, 12:11 AM
SwiftyR SwiftyR is offline
Send a message via AIM to SwiftyR
Personally I wouldnt mess with the brakes.... Let a pro do it so u know its done right.... U dont want to be doin 80 on the highway and not be able to stop
Old 03-04-2002, 11:55 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
yea it sounds like a master cylinder to me too.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 03-05-2002, 12:26 AM
its the master cylinder, so it'll have to be replaced. I changed the master cylinder on my old accord. Its not too complicated, but time consuming just b/c it was the first time i ever changed a master cylinder. If you dont want to mess with it, take it to a brake shop. But it definitely needs to be replaced.
Old 03-05-2002, 02:42 PM
eric26's Avatar
Thumbs up
thank u guys i will do that.and what parts can i use for my b16a, like headers, cam gears and pulleys ets
SOON TO GET.
5 speed swap.
Old 09-23-2004, 11:52 AM
integr95 integr95 is offline
Question
Hi, just looking through the faqs. I have the exact same problem with a 95 integra. It has a new master cylinder. The master cylinder was loosing fluid?? But very slowly. I lent the car out and when I got it back the brakes were going to the floor. So I filled the reservoir. The brakes were still very mushy and wouldn't begin to engage until they were near the floor. So I took it and had the lines bled. Now the brakes will engage right away, (as they should) but while sitting at a light, they will go to the floor.... ??? Master cylinder is not loosing fluid and again, is new (rebuilt). Does this possibly sounds like the brakes assist module (I think that is what it is called) or does it sound more like a bad master cylinder? I apologize for the length of this post, Any suggestions or assistance would be great appreciated. Tx Rad
Old 09-23-2004, 05:31 PM
Mendari Mendari is offline
Re: no brake power
It still appears that the Brake fluid needs to be bled out properly. The smallest air bubble will cause a loss of pressure.
ABS Hydraulic Unit tips for rebuilding bertpalm General Discussion 0 01-16-2010 08:00 PM
brake problem, VERY hard brake pedal but VERY little braking power 95GMCJimmySLE Problem Diagnosis 23 10-24-2009 03:41 PM
99 T&C Power Brake Booster Squeal? SlimJimRD Caravan | Voyager 1 06-29-2009 10:28 PM
Brake Booster replacement causes brake lights to stay on, and brake power is VERY low Ultranpthing Let's get Technical! 8 09-22-2005 06:15 PM
Braking Power... Where has it gone ashah000 Off-Topic 5 03-05-2004 06:06 PM
