Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 11-30-2004, 10:59 AM
djfred djfred is offline
How to remove yellow inserts from Yukon Headlight??
one day i saw one guy with a GMC pickup with the same headlamps I have on my 04 yukon without that ugly YELLOW thing inside the headlamps.... how do we take it off to make it clear?? Thanks IA !
Old 12-03-2004, 06:17 PM
attackdog attackdog is offline
Re: How to remove yellow inserts from Yukon Headlight??
I don't think you can remove the insert. I picked up aftermarket clears for mine. Good luck.
Old 12-05-2004, 05:13 AM
nali02's Avatar
nali02 nali02 is offline
i too have wondered about removing that marker lense from the headlights. i dont want aftermarket projector headlights since most aftermarket crap is exactly that, crap. ive read tutorials that people wrote on how to retro-fit reflector headlamps into projector ones where they just put their headlamps in the oven for about 15 minutes (not sure the temp off the top of my head) and this allows the lense to be removed from the housing, which would give you access to that little yellow marker, but since i have no idea if it can even be removed i have yet to try.
Old 12-06-2004, 01:21 PM
tonytone tonytone is offline
Bottom line--the only way to remove the yellow reflectors from the OEM housing is to split the housing open; how you go about doing this is your choice...
Old 02-10-2005, 05:04 PM
the_nali the_nali is offline
buy it on e-bay for $27.00
Old 02-10-2005, 06:07 PM
Eggert Eggert is offline
HI, do what I did and get the aftermarket projector lamps for the Denali. It is WELL WORTH IT.
This thread has a link where I bought my pair of projector lamps for $260:
http://www.automotiveforums.com/vbul...d.php?t=208142
Take care, Eggert
Old 02-11-2005, 04:33 PM
Jeepin_CJ7 Jeepin_CJ7 is offline
Here ya go...
Do you mean like this?
http://www.gmfullsize.com/Tech%20Pag...ght%20Mod.html
Old 02-12-2005, 08:38 PM
cornbuzzard cornbuzzard is offline
Hello, i work for an automotive lighting company, the amber reflex reflector is required by FMVSS, if you remove, its not legal. Also, you will not be able to remove w/o damaging the lamp beyond repair.
Old 04-04-2005, 05:45 PM
C'on man give us a break! save your lecture =P
Old 04-04-2005, 05:47 PM
Thumbs up Re: Here ya go...
Originally Posted by Jeepin_CJ7
THAT IS WHAT I WAS LOOKING FOR MAN!!! Thankssss you're the best
Old 04-06-2005, 02:09 AM
BLAZT BLAZT is offline
Dont listen to cornbuzzard. I have a Grand Cherokee with clear corners and my turn signals are Ultra white. No more ugly looking amber. Driving in L.A cops have seen the turn signals and they dont say nothing. Where I got my clear corners I saw the clear headlight assembly for the yukons and tahoes but did not ask for price. They look much better without the Orange Amber. Good Luck.
Old 04-07-2005, 05:25 AM
YukonGMC YukonGMC is offline
I tried that procedure in the link where you seperate the lens from the light body by running a screwdriver around it.. Crap, I couldn't get the two pieces apart. Too snug and plastic will break. Wonder how he did it so well ? I gave up.
Old 04-08-2005, 08:44 AM
Hi,
that is because you are not supposed to do this but can get 'lucky' sometimes.
There is a reason for the yellow reflectors, like other people may see you better and that may save you, too...
Take care, Eggert
Old 04-09-2005, 08:21 AM
Wink Re: How to remove yellow inserts from Yukon Headlight??
These lamps were made my Guide corp (my competitor, at least for another year or so), so the seal is probably two part urethane or hot melt adhesive, either way, if you pried on the lamp seal joint with a screw driver, you compromised the glue joint and your lamp will have moisture in it in the future. If that moisture contacts your lit bulb, it will fail. So it will look bad and not work. Dont listen to these guys, they have no clue what they are messing with.
Old 05-03-2005, 02:31 AM
nali02's Avatar
just use a heat gun to heat the glue holding the lense and it should come right off. then simply reheat the glue when putting the lense cover back on to seal it back up, you wont have to worry about moisture or anything.
02 Yukon Denali
Exterior
- 22" VCT Scarface rims on Toyo Proxies 305/45/22
- K&N FIPK intake
- Pewter GMC grille emblem & clear parking lenses
- 4100k Hid's
- Escalade doorhandles & roof rack
Interior
- Alpine iva-d300 7" indash DVD/mp3/wma
- Sirius satellite radio
- 2 JL Audio 12w6v2 subs
- 1 JL Audio 1000/1 amp (subs)
- 1 JL Audio 300/4 amp (mids/highs)
- MB Quart components all around
- Clear Limited Edition Xbox w/ 160gig hdd
- K40 Undetectable dual radar w/ lazer defuser
