Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 11-29-2004, 07:11 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
I have a question. or two
ok, im trying to learn everything about turbo chargers and forced induction systems but am a little bit confused about everything. Where does the wastegate bolt up onto?? like in this picture i know it mounts to the manifold after the turbine housing, but where does this second port connect to??
And also, does anyone have a diagram on where all the lines hook up on the turbo, BOV, wastegate, ect... I dont need a scientific diagram or anything (unless you have one) even a good reference made on paint would help me out lol I also have searched google and this forum and still have come up mostly empty handed... THanks.
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 11-29-2004, 07:12 PM
Re: I have a question. or two
oh yeah and im not talking about the port right there on the manifold, im talking about the one on the side of the wastegate..
1988 conquest TSI
Torque wins races!
Old 11-30-2004, 02:24 PM
SaabJohan SaabJohan is offline
The wastegate is just hooked up with the exhaust system, or so has it an exhaust system of its own.
This is how the setup can look on a modern turbo engine.
Old 11-30-2004, 06:37 PM
this does help, but im still unaware of the external wastegate. That pic does help but the fact that its using internal WG i am still confused...
1988 conquest TSI
Torque wins races!
Old 11-30-2004, 08:23 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
The exhaust needs to split before the turbine. The one side goes to the turbine and the other side goes to the wastegate. After a certain boost is reached (referenced by a line to the compressor side) the wastegate opens allowing exhaust to bypass the turbine. Most wastegates dump the exhaust back into the original downpipe, but for max effort turbo-ing the wastegate should have its own exhaust.
I don't have any good pictures, but the wastegate is just a spring loaded pressure regulator. The pressure coming from the compressor side forces the spring open and opens the wastegate. By adjusting the spring tension, you adjust at what intake pressure the wastegate opens. The picture that SaabJohann posted shows an integral wastegate that is cast into the turbine housing. Again, fine for most systems but for max effort turbo power, better plumbing is afforded with an external wastegate. Your picture is of an external wastegate and there is no turbo currently on the manifold
The port on the side of the wastegate in the picture you posted is the exhaust for the 'gate. That is the port the puts the exhaust back in the downpipe.
Dragging people kicking and screaming into the enlightenment.
Old 11-30-2004, 10:40 PM
so lets say it had its own exhaust, would DEQ say anything about it putting out that pure exhaust straight out? lol, that a wierd question but...Yeah i understand how the internal wastegate works, but i am more suited towards getting an external. Thanks for the help...
1988 conquest TSI
Torque wins races!
Old 12-01-2004, 12:29 PM
Re: Re: I have a question. or two
If your car needs to follow sound and emission regulations (where a cat. is used) it would probably not be allowed to use a separate exhaust pipe for the wastegate. In most applications it's good enough to wait for about .5 meters after the turbine and then feed it back into the exhaust system.
Old 12-05-2004, 05:06 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
I have also heard that it is a good idea to make sure the wastegated exhaust enters back into the exhaust at an angle. It helps prevent boost creep.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 12-08-2004, 09:28 PM
an angle? like how much of an angle?
1988 conquest TSI
Torque wins races!
Old 12-09-2004, 01:02 AM
240SX Guy
45* is usually a good round number. More is a plus. You just don't want to have any pressure from exhaust on that pipe. At an angle, you will get a little vacuum as well. It helps to avoid boost creep.
-Cory
12.6@122mph
Old 12-09-2004, 01:03 AM
240SX Guy
Note the Blow Off Valve recirculation too scenes how you plan to KA-T.
-Cory
12.6@122mph
Old 12-09-2004, 11:17 AM
psychorallyfreak's Avatar
psychorallyfreak psychorallyfreak is offline
Send a message via ICQ to psychorallyfreak Send a message via AIM to psychorallyfreak Send a message via MSN to psychorallyfreak Send a message via Yahoo to psychorallyfreak
45 degrees is actually pushing it, IMO. More along the lines of 20 or so. Run the pipes next to each other, then just splice them in gently...if you can see it in your mind, it helps a lot more....
