Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 11-28-2004, 02:57 PM
bigbob bigbob is offline
cam lift
tw heads/tfs stage II cam/ is the valves gunna hit the stock pistons? if so what abotu teh stage I
95 gt vert
built aode
underdrive pullies
slp cat back
bbk o/road h
nos dry 80 shot
Old 11-28-2004, 05:31 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: cam lift
Twisted wedges usually require flycut pistons with any cam...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 11-28-2004, 08:08 PM
Re: cam lift
how do you get the pistons out? you have to take the whole rotating assembly out dont ya? cuz that blows maybe ill supercharge it and worry about that when i have more time.
95 gt vert
built aode
underdrive pullies
slp cat back
bbk o/road h
nos dry 80 shot
Old 11-28-2004, 09:32 PM
eillob's Avatar
eillob eillob is offline
Re: Re: cam lift
Correct me if im wrong because I could be but aren't those heads designed so you don't have to have flycut pistons.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 11-29-2004, 04:06 PM
Re: cam lift
i just asked over at mustangexhaust.com and i had a reply sayin ghe thought if i retained the stock valves i can use up to a .550 lift on stock pistons! is that tru anyone
95 gt vert
built aode
underdrive pullies
slp cat back
bbk o/road h
nos dry 80 shot
Old 11-29-2004, 06:08 PM
eillob's Avatar
Re: Re: cam lift
Hmmmm, I would research that a little maybe someone here with a little better expertise could better answer that. My question is, why waste the time putting a cam like that in and still have to deal with the smallish valves in the stock heads? Even if you get away with the lift your still dealing with 1.78/1.46 valves. Get better heads with larger valves and you won't need that kind of lift to make power.
Old 11-29-2004, 06:31 PM
Re: cam lift
i was plaining on the twisted wedge heads not stock
95 gt vert
built aode
underdrive pullies
slp cat back
bbk o/road h
nos dry 80 shot
Old 12-02-2004, 07:26 PM
Re: cam lift
Stock heads/valves will usually clear up close to .550. I ran .513/529 on stock pistons and stock GT-40 heads. It's also gonna depend on your duration. My duration is only 216/220.
I may be wrong about the TW heads. I don't remember now, I avoid those like the plague after I saw what happens after a few thousand miles of a Ford motor running a Chevy valve angle...
Freedom Isn't Free.
Old 12-02-2004, 07:36 PM
eillob's Avatar
I've heard rottent things about twisted wedge heads, but I've never seen any articles, can you elaborate.
Old 12-02-2004, 08:25 PM
Re: cam lift
It hasn't really been covered in mags, TFS must really pay well for their ads, but read around some of the dedicated Mustang forums and you will learn that TW's have a bad rep for pounding out spring perches, damaging pushrods, and valve guide issues. They work extremely well for a while, but they are time bombs. It isn't seen as much now because everyone who would normally have jumped on the TW bandwagon is out buying AFR 165's or 185's.
I'm curious about your heads, I was considering Windsor Jr. Lites myself, but I'm back on the GT-40X path after seeing flow #'s on the iron Windsor Jr.s-they were about the same as my GT-40 Irons.
Freedom Isn't Free.
Old 12-02-2004, 08:42 PM
eillob's Avatar
Well I got lucky, I too was a little concerned about the flow #s myself but the guy I bought these from had full bowl work to unshroud the valves and had lots of work done to the exhaust ports to improve flow around the valve seat. The flow sheet on these heads were 240 cfm on intake and 200 cfm on exhaust @ .500 lift. I gains loads of torque when I bolted them on so I am very happy with them. If I hadn't found these I was looking at the 180 Roush heads. Check them out.
http://www.racerwalsh.com/v8_cylinder_heads.htm
These heads are supposed to be the new and improved windsor Jr's I've got a friend with these heads and he runs very well low 13's.
Old 12-02-2004, 08:49 PM
Re: cam lift
Already checked out the 180s. Problem is, I want aluminum (11:1 comp. sounds way cooler than 9.5:1) for weight savings and other reasons. I'm pretty much set now on getting GT-40 X 305's (58cc) and doing my own port work (gasket match and CC match the chambers), and mill them for stud mount rockers/guideplates.
Freedom Isn't Free.
Old 12-08-2004, 04:38 PM
Re: cam lift
how do you find out what you compression ratio, and displacment will be after new heads? is there an easy formula for these? thanks the craig
95 gt vert
built aode
underdrive pullies
slp cat back
bbk o/road h
nos dry 80 shot
Old 12-08-2004, 06:10 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: Re: cam lift
Displacement does not change with a head change ie. combustion chamber size change.
Static CR does have a formula to calculate it and no it is not easy.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 12-16-2004, 12:20 AM
runningmole runningmole is offline
Send a message via AIM to runningmole
Re: cam lift
You can use TW heads w/o flycutting. You should clay your pistons though to measure the clearance. I doubt the stage 2 cam will work. Stage 1 cam will work though
1993 Mustang GT
Blue/Titanium 2tone, 5spd, 3.55s, JBA ceramic shorties, catted H-pipe, dumped Magnaflows, MSD goodies, FMS alum rad, Pro50, balanced/blueprinted forged 327 stroker (8.2 compression), AFR 185s, Performer RPM, 70mm TB, FTI custom cam, SFC, In-floor Subframes, Maximum Motorsports Torque Arm and Panhard Bar, H&R Springs, Bilsteins, MM CC plates, 5 Lug Conversion w/ Silver Bullitts. Full accessories including smog legal. 310rwhp 351rwtq Dyno Dynamics Dyno. Soon to be supercharged
