Old 11-25-2004, 01:00 AM
Future303 Future303 is offline
Are Carbon Hoods worth it?
I mean they take off like 30lbs from your front, and that should make a difference to acceleration, not to mention slightly higher mileage.
I have heard that they are dangerous in an accident, because instead of crumpling, they will slice thru the cabin, along with any passengers there.
Any opinions?
95 GT AKA "The Purple Hippo". Stock 302 bottom end. Edelbrock Heads. Performer 5.0 Intake, 1.7 RR's on stock Cam, Stock T5, 3.27 gears, UD Pullies, K&N Filter, rubber boot deleted, A/C deleted, BBK Catted X-Pipe, 180º TStat, EEC Tuner running J4J1 stock BIN. AEM WB02, Minor tunes, running pig rich. No clue as to RWHP feels a tad faster than a stock 05 GT.
Old 11-25-2004, 12:11 PM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
Re: Are Carbon Hoods worth it?
go with fiberglass if your worried about that
Old 11-25-2004, 12:37 PM
HighRev87's Avatar
HighRev87 HighRev87 is offline
Banned
As much as it might help, alot of domestics dont bother with cf, it really (although shouldnt be) is a rice thing. Although most of them dont have true carbon fiber, it is still associated with those civics with painted black hoods. If a good fiberglass kit is available, id probally go for that.
Old 11-25-2004, 02:08 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
i agree i would stick with a fiberglass one.
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 11-25-2004, 03:18 PM
Escort_Service Escort_Service is offline
Fibre Glass is not a strong as CF and not as heat resistant
Old 11-25-2004, 04:27 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: Re: Are Carbon Hoods worth it?
true, but it's a hell of a lot less expensive and when unpainted, it doesn't make your car look ricy
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 11-25-2004, 06:40 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
CF is not worth it... you can pick my fiberglass hood up by yaself it weights barely anything. CF will save you maybe a pound or two and for what pretty much double the cost?
Take the money saved go buy gears and a fiberglass hood and it will do 10X what just the CF hood would do.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 11-25-2004, 07:13 PM
HighRev87's Avatar
Banned
Im not really into hood replacement right now, but wouldnt a light weight hood need pins or something of the sort to hold it right at high speeds? Or would it be ok with an oem latch?
Old 11-25-2004, 09:34 PM
lckycharm713's Avatar
lckycharm713 lckycharm713 is offline
the stock hoods on mustangs are fiberglass, how much lighter can you go. stay fiberglass. besides, i think that CF look tacky on a mustang, its like a big old nasty wing, they just dont belong on muscle cars
2000 Mustang - just a V6 with lots of good looks
1974 Camaro - 350 4bolt main .30 over, turbo 350 trans w/ shift kit.
1999 F-150 Lariat 4x4 5.4L
"Only babies suck bottles (NOS)"
Old 11-25-2004, 11:03 PM
Grey03Cobra's Avatar
Grey03Cobra Grey03Cobra is offline
A fiberglass hood should be okay with the OEM latch (I think the stock hoods are fiberglass anyways). With CF hood pins are a good idea.
2003 Mustang Cobra Turbo
811rwhp
2009 Audi A5 S-Line
2005 Pontiac GTO
Old 11-25-2004, 11:54 PM
whoisdabomb86 whoisdabomb86 is offline
Send a message via AIM to whoisdabomb86
4 " full liftoff fiberglass cowl for me, cost me 250$ shaved at least 35 lbs from the front and and made noticable differeance in acceleration. its not a problem to take off myself but pain in ass
Old 11-25-2004, 11:57 PM
stock hoods are steel guys...
if you get a fiberglass hood and don't want hood pins guy a bolt-on hood. it accepts your stock latch and hinges.
-Andy
Old 11-26-2004, 12:04 AM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
'94 and later stockers are a composite material. Not fiberglass, but not steel either.
I agree, save money and go fiberglass.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 11-26-2004, 06:05 PM
GTStang's Avatar
Stang Guy
96-04 Hoods and trucklids are made out of a composite that is pretty much like fiberglass slightly different.
Fiberglass hoods can be bought two ways:
Lift-off/Pin-down style: no supporting structure underneath so you need hood pins to hold it down cause there is no place for the stock hood latch or hinges.
OEM style: Fiberglass hoods can also be bought with a full structural support underneath and metal backing plates to use the stock hinges and the stock hood latch. These are perfectly fine I have had one on my car for two years without hoods pins and iot has never come undone on me or anything like that. I'll try to post pics of the underside of my hood later.
Note: Hood pins are a good idea wether you have the stock OEM steel or an Aftermerket fiberglass hood. I have seen the stock hood latch and safety latch fail on bother aftermarket fiberglass and stock OEM hoods it's not pretty.
This is a pic of what happens when the hood comes up on the hioghway.
Old 11-26-2004, 06:08 PM
Xtreme_098's Avatar
Xtreme_098 Xtreme_098 is offline
Send a message via MSN to Xtreme_098
It does help with your weight distribution. You can get them painted to match the car. Its about performance not the looks of it.
