Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 02-25-2002, 09:54 PM
a/cauthority a/cauthority is offline
help need piston rings!
hey guys i need a set of aftermarket piston rings for a h22a1
any help would be appreciated
i cant get them through ITM they are on back order!!
any body know who carries them may have a set on the shelf?
any info or links to parts houses will be appreciated
no luck with the GOOGLE search.
thanx again
Old 02-26-2002, 02:24 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
I know that Arias, JE, and Total Seal all make rings for the H22. Try calling Summit ( www.summitracing.com ) - they should be able to hook you up and they have great prices too. (Note that their on-line catalog is incomplete - you'll have to call). Make sure you have the ring dimensions (bore & thickness) to double-check before you order.
If Summit is no help, I'm quite sure that JG engine dynamics can help you out (they carry the JE line). But they may charge a premium.
http://www.jgenginedynamics.com/home
Good luck.
Need Help....Pistons, Rings and Cam for 2.5L ELESWON S-10 1 07-08-2004 05:25 PM
Piston Rings?? HELP!!! 90CRX661 Engineering/ Technical 8 12-02-2003 01:43 AM
Need help on deciding which piston rings to use?? hayhursm Forced Induction 3 11-05-2003 12:33 AM
help! piston rings a/cauthority Engineering/ Technical 1 02-26-2002 07:59 PM
