Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-22-2003, 12:21 AM
hayhursm hayhursm is offline
Send a message via AIM to hayhursm
Need help on deciding which piston rings to use??
Heres the setup, I have a B16a2 block that has been sleeved, bored (81.5mm), and o-ringed by AEBS. I have Wiseco (9:1) pistons and Eagle rods. The piston rings that came with the piston set are alright, but when compared to the stock Honda piston rings the Honda ones are much stronger (especially on the second ring). I was looking at Total Seal but have not heard a lot about them. I read an article in Honda Tuning where Erick Aguilar used stock Honda rings because of the quality, my only problem is that I don't think Honda makes a ring for an 81.5mm bore. Boost wise I plan to run about 15 psi on regular pump gas, for street use, and at least 26-28 psi on the track with C16. Possibility for nitrous to be dumped in the engine also, for I already have a dry setup. PLEASE!! If anyone has any advice or has already had experience with this don't hesitate to let me know.
email: [email protected]
Thank you
Marcus
Old 10-31-2003, 12:08 PM
redmanjd redmanjd is offline
total seal rings kick ass
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 10-31-2003, 02:12 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Need help on deciding which piston rings to use??
can you even run 15psi daily on pump gas...that seems like it's a bit high, but then the highest octane we get around here is 92.
Empty Pockets Racing Member #1
Old 11-05-2003, 12:33 AM
Re: Re: Need help on deciding which piston rings to use??
You might be right I am not really sure I am sure I will find out though after I increase the boost in increments and watch for knock.
