Old 02-25-2002, 09:31 PM
changedagame108 changedagame108 is offline
spark plug replacement
How often should spark plugs be replaced in a 96 civic?
Old 02-25-2002, 11:20 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
as long as the spark plug is working properly, the gap is right and the electrode is not round up (you can service the electode by filing it and re-gap it) then you should be fine (except for carburetor cars and those are not computer control).
I think the OEM manuel says somthing like for every 100,000 miles, the spark plugs should be replace.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 02-26-2002, 12:12 AM
praxis praxis is offline
The manual actually says that you should check your plugs and replace if necessary, every 15,000 miles.
PraxisPerformanceAutoworks LLC High performance autoparts & accessories.
________________________
sales and specials...Konig wheels, Accmat carpets, Thermal exhaust, DragunFire mufflers
_____________________________
PraxisForums...informative information
PraxisRacing is sponsoring. click for more info.
see PureHonda in its original colors-->
Old 02-27-2002, 05:49 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Always good to check your plugs often and replace them if they needed. If you forget to check though, when they've gone bad, you should notice a distinctive stuttering. When this first happened to me, I described it as feeling like the engine couldn't get enough fuel. It was actually bad plugs not firing properly.
There's no replacement for displacement...No, not even a turbo.
E150 5.4L Spark Plug Replacement leroge Econoline 1 04-19-2010 08:19 PM
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
3.5L spark plug replacement, how to? stickapp1 Intrigue 1 12-18-2003 12:13 PM
ES300 spark plugs replacement lshatsma ES300/ES330/Windom 3 08-17-2003 04:23 AM
1992 325I Air filter replacement and spark plug replacement rdog28 3 Series 4 07-13-2003 03:47 PM
