Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 02-25-2002, 08:57 PM
neunan neunan is offline
Send a message via AIM to neunan
Question hard rubber vs polyurethane bushings
i was reading some old posts and saw one on Energy Suspension polyurethane bushings, which i planned on getting for my ride whenever i drop the money for Prokit and koni yellows. somebody said that with harsh weather polyurethane would "act like cement" and itd be better to go with hard rubber. what? and if thats right, who sells hard rubber kits similar to energy suspensions? think Chicago weather.
96 Accord EX 5spd coupe - black
AEM cai * DC Sports cc 4-2-1 header * GReddy EVO catback* AEM trupower pullies * ACT HDSS clutch kit * ClutchMasters 8lb flywheel * NGK blue wires * 4 wheel Brembo slotted rotors with AEM pads * 4bidden Motorsports shortshifter
pioneer deh9300 * phoenix gold zero point wiring * blaupunkt pa2100 pushing diamond audio HEX 6.5 comps in front * blaupunkt pa275 pushing power acoustik fahrenheit 6x9s in back* 5" LCD TV * 8-bit original NES
Old 02-25-2002, 10:15 PM
Firebird Firebird is offline
I live about 60 miles from Chicago, I got a set of polygraphite bushings from PST I'm sure they make a kit for yours, I love them, they are alot better than the origanal rubber ones. they do make squeky noises when it's cold by a little silicon spray and your back in bisness, also you mentioned a prokit ( I assume you mean Eibach's kit, right) if so they make awesome springs my cars handling is so tight after putting them on it's incredible. It won't even lean going around corners and I've never made it break loose (and I've tried pretty hard) they are awesome you'll like them.
1989 Nissan 240sx XE(coupe) stock except K&N air filter, and some of the ugliest wheels ever >.<
Old 02-26-2002, 03:21 PM
k thanks
Old 02-27-2002, 02:03 PM
DemonicAccord's Avatar
DemonicAccord DemonicAccord is offline
Send a message via AIM to DemonicAccord
PU bushing overratted. I have several friends that have gone back to OE rubber. after extended conversations with most of them I am now no longer entertaining the full bushing replacement route, however I will be replacing my shifter bushings w/ an Energy set. I know some people like them, I don't think its worthwhile unless you're hitting the track every weekend,
jm2c
Old 02-28-2002, 12:28 AM
i just looked at it as a fairly cheap mod ($50-$100) that could possibly improve my handling - now i've got one comment in either direction. anybody else had experience? whats the difference in ride between stock, hard rubber, and polyurethane? and ive never hit the track in my life, its a daily driver that i race for fun. take turns kinda sharp sometimes...
Old 02-28-2002, 02:04 AM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
ive heard of bolts just snapping because there is nowhere for the energy to be absorbed. im sure whoever did it was beating the shit out of thier car but still. oh and one thing i will say is dont ever get the motor mount inserts. there are much better ways to get a massage then that!! i know from personal experience on that one.
oh and the difference in ride is its stiffer.
Old 02-28-2002, 02:50 AM
rubber is cool too
Old 02-28-2002, 07:10 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
i've road raced a crx with urethane bushings installed on all points. handled really well, very stable and accurate... no slop.
i think they're worth the money... but beware, they will transmit every bump, jolt, jitter, and rumble into the passenger compartment. the ride will be stiffer and louder.
as for bolts snapping off, i have never seen that problem. maybe whoever installed them used the wrong set or non-hardened bolts.
Old 03-01-2002, 07:05 PM
now that I think about it the ride was probably a little rougher after I installed them but I installed them at the same time as the Eibach springs so I didn't know if it was the springs or the bushings or a combo of both that made for the rougher ride. like drift pointed out the handling is tightened up a lot. You will deffinetly be able to tell the difference, I have never raced mine either but I enjoy driving a lot more now even if the ride is a little rougher.
rubber or polyurethane bushings alphalanos Wheels/Tires/Suspension 3 03-24-2005 04:35 PM
Polyurethane Bushings Instalation S13wanabe Wheels/Tires/Suspension 4 11-26-2004 09:47 AM
Polyurethane bushings for 99-00 Si rear sway bar chimchim '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 01-27-2004 03:41 PM
polyurethane bushings xlosinghopex Tires and Wheels 3 06-30-2003 10:42 AM
polyurethane bushings natedogs911 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 5 01-28-2003 10:57 AM
