Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 03-20-2005, 11:39 AM
alphalanos alphalanos is offline
rubber or polyurethane bushings
im looking at some control arms from Ingalls. they offer either rubber or poly bushings. what is the difference? (besides the material or course)
96 EJ6. Future home of boosted B18C1.
Old 03-20-2005, 12:45 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: rubber or polyurethane bushings
The rubber is softer and more compliant so on regular roads it will not be as rough. Also they don't/shouldn't need greasing.
Whereas the polyurethane bushings are harder and you will feel bumps more and definitely need to be greased every once in awhile unless you don't mind squeaks.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 03-24-2005, 04:32 PM
mrgofast21018's Avatar
mrgofast21018 mrgofast21018 is offline
Send a message via AIM to mrgofast21018
if you get graphite impregnated polyurethane bushings they tend to squeak less. alot less. i think they cost a tad bit more tho.
Old 03-24-2005, 04:35 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
eveyone failed to mention that polyurethane bushings also last 10 times longer than rubber bushings. Also, since the poly's don't flex as much, they offer tighter responce and less "setting".
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
