Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 11-19-2004, 10:03 AM
deadlywhispr18's Avatar
deadlywhispr18 deadlywhispr18 is offline
Send a message via AIM to deadlywhispr18
can i get some help here
without buying any new wheels for a car. How can I find out the largest size wheel and tire i can put on????? Sorry if this has already been asked.
"And with the whistling of the nights winds, we begin to feel an urge to fly."
Old 11-19-2004, 10:59 AM
C-DUBYA C-DUBYA is offline
Go to a tire shop they can usually tell you right away.
www.toontoys.ca
THE WAY YOUR GIRLFRIEND LIKES IT...BIG AND DIRTY!!
Old 11-19-2004, 11:00 AM
Re: can i get some help here
yea i figured that one but i was just wondering if there was something i could do on my own, i like doing things once or twice just so i know how something is done for future reference...thanks though.
Old 11-19-2004, 12:44 PM
csaxon csaxon is offline
Adding inches to the wheel diameter for wider, low aspect ratio tires can increase your car’s handling capabilities.
Plus Zero
Increase the section width and lower the aspect ratio while retaining the wheel diameter. This replacement tire increases the contact area and lowers the tread profile for improved traction and quicker response.
Plus One
This sizing mounts tires with an increased section width and a lower aspect ratio on wheels of a wider diameter. A Plus One fitment for a car with 14-inch original equipment wheels would use 15-inch wheels.
As a general rule of thumb, Plus One Sizing:
Increases section width by 10 mm.
Decreases aspect ratio by 10 points.
Increases rim diameter by 1 inch.
Plus Two
Increased wheel widths in plus sizing also contribute to greater tire stability, and improved cornering and maneuverability. A Plus Two fitment for a car with 13-inch original equipment wheels would use 15-inch wheels.
As a general rule of thumb, Plus Two Sizing:
Increases section width by 20 mm.
Decreases aspect ratio by 20 points.
Increases rim diameter by 2 inch.
Plus sizing can effect your abs sensors. Dealers have additional information for Plus Sizing ABS-equipped vehicles.
It worked fine until I fixed it!
Old 11-28-2004, 10:04 PM
campfire9 campfire9 is offline
Go to 1010tire.com. Then click on the tire size calcuator and follow instructions. It will tell you what you want to know.
campfire9
Old 11-29-2004, 12:08 AM
that site should be 1010tires.com
