Old 11-19-2004, 01:26 AM
malsheem's Avatar
malsheem malsheem is offline
20 inches and growing ...
Homemade P/E parts problems & questions
Okay, I was giving making my own P/E parts a try using the various resources out on the Internet. I tried the direct toner method since all the equipment is readily available to me. I started with a image of my fret, Fabulous logos for my Fabulous Celsior project. I printed it on 3M transparency paper using an HP LaserJet printer.
So far, so good. Image looks workable. So then I tried to use an iron to transfer the toner onto a brass sheet. I set it to medium-high and left it on the transparency for a few minutes. Then I pulled off the iron. Whiff. It didn't transfer properly. I figured okay let's leave it on longer. Nope. Okay, how about a little hotter. Nope. I've gotten it to the point where the transparency starts to deform.
So what am I doing wrong? The stuff on the web doesn't give specifics on how hot to set the iron or how long, but it shouldn't be this difficult, should it? Any ideas or tips from those who have tried this would be greatly appreciated. Thanks.
-Joe
www.quietrage.com
CWest R34 Skyline GT-R
Old 11-19-2004, 04:43 AM
deedlit's Avatar
deedlit deedlit is offline
Re: Homemade P/E parts problems & questions
I've never tried but why trying to put the ink on the brass?
If I remember correctly what my dad was doing with his Integrated Circuits.
You will certainly insulate the brass with UV lamps, isn't it? So why not let the clear sheet over the brass, insulate it, remove the clear and then put it in the acid?
Sorry if I've said something wrong, I was a little child when my dad was playing with electronic stuff.
Old 11-19-2004, 05:26 AM
flyonthewall's Avatar
Car Mod guy
Can't help you with the transfer issue coz not familiar with it but here is something you will need to consider...
When you etch metal, any part of the design can be no thinner than the thickness of the metal. So for example the letters in the logo must be to the same thickness as the metal you are using. You may already know this but I point it out coz some of the letters look very fine, in particular the sprue you have connecting them all.
Incidently a way around the transfer issue is to use metal with a UV coating or coat the metal your self. You will then use your transparency image over the metal as you expose it to UV light. This is how its done professionally so may yield better results in the bedroom/kitchen/shed/workshop.
Old 11-19-2004, 07:41 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Good Question, but sorry I don't know the answer but if you find out a "How To" on the subject would be great.
Steve a.k.a. Hiroboy
Old 11-19-2004, 08:42 AM
Inservible's Avatar
Inservible Inservible is offline
Send a message via ICQ to Inservible Send a message via MSN to Inservible Send a message via Yahoo to Inservible
You have to use white glossy paper for this method, the transparency paper it's only useful for UV transfer. There is a hot transfer paper too, it is used to transfer the image from the paper to a t-shirt by means of a hot iron!!
HTH
Mark
Current Project:
'57 Chevy Bel-Air
'55 Mercedes 300SL "Gull wing"
Old 11-19-2004, 09:09 AM
malsheem's Avatar
Chris, I read the fact about thin pieces no thinner than the thickness of the metal. I am worried that the connecting parts are too small, but won't know till I get to the etching point. Just trying to get a good resist image first.
I'll play around with this some more, maybe with a larger, less complex design (etched gas/brake pedals or something). Maybe this design is a bit too complex for a first try. Might give the photosensitive method a try if that fails.
Here is the tutorial I used for the P/E parts. http://modeltech.tripod.com/etching2.htm
Text from the direct toner section.
3.Direct toner transfer. This method involves using laser printer or copier toner as the resist. Using this process you make copies of your art, either with a laser printer or a quality copier, onto transparency film, available from an office supply store (Kapton seems to be the preferred choice here). These copies are laid face (toner) side down onto the metal and , using heat from a household iron, the toner is "melted" onto the metal forming an etchant resistant barrier.
Using the direct transfer method: All areas covered by the toner (resist in this case) will be left behind. See though areas will be etched away. However, any lettering must be done backwards, as the transfer procedure reverses the direction of the text.
-Joe
www.quietrage.com
Old 11-19-2004, 11:00 AM
Inservible's Avatar
As you wish!!
Mark
Current Project:
'57 Chevy Bel-Air
Old 11-19-2004, 01:23 PM
Murco's Avatar
Murco Murco is offline
Maximum Car Guy
Send a message via Yahoo to Murco
This is the only non-pro method I've ever seen that worked well and consistently for my friends who've tried it. This is far beyond anything I want to try!!
My AF Classic Model Car Gallery
Old 11-21-2004, 12:29 AM
Midnight Racer's Avatar
Here some info that might help you
http://s96920072.onlinehome.us/Fea1/...rt/fea688.html
Old 11-22-2004, 03:03 PM
Murco's Avatar
Maximum Car Guy
Originally Posted by Midnight Racer
Hmmm, might have to try this out!!
