Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-25-2002, 06:22 PM
buh_buh's Avatar
buh_buh buh_buh is offline
Send a message via ICQ to buh_buh
H22 + turbo = bad?
That is what I have read. I don't know if this is true or not. I read this is true because it had something to do with the VTEC and turbo not working well together. What's the real deal? I have a H22 and I eventually want to go turbo route. So what are the downfalls?
AF Nordic Crew #3
Old 02-25-2002, 07:23 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
mine works just fine.
Old 02-25-2002, 10:13 PM
phattycrx phattycrx is offline
you want to know what will happen????
you will have a very fast car....
Old 02-26-2002, 05:10 AM
VTECseoul VTECseoul is offline
Send a message via AIM to VTECseoul
the theory is that the normally aspirated cam is designed to have what is called crossover; when both intake & exhaust valves are pushed open to help clean out the chamber of the spent combustion. when adding forced induction, the boosted air is "believed" to be wasted when this happens, thus losing "true" boost.
a cam designed for turbo is cut to eliminate having this, or has it (crossover) in a shorter amount of time. Don't believe the hype, a friend has a GS-R turbo running 300+ hp w/ stock block; & advancing the exhaust cam only gained 2-3 hp.
2000 Honda Accord LX Satin Silver Sedan
AEM ColdAirIntake
Neuspeed Sport Springs
Nitto 450 225/50
Prime Racing M8 17x7
S15 vs AE86 - 2006 HotWheels Touge
Old 02-28-2002, 02:00 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
What VTECseoul is calling "crossover" is usually called "overlap". And yes, high-RPM NA engines want more overlap than FI engines.
BUT - since the H22A is a DOHC engine, with the simple addition of adjustable cam gears you can dial the overlap to any figure you want. How cool is that? Advance the intake cam and retard the exaust cam to remove overlap, or vice versa to add overlap.
I'm also under the impression that the stock amount of overlap in the cams really isn't too bad for a low pressure ~6psi turbo. You might only adjust it a couple of degrees for peak power.
H22As do great with boost. Where did you read otherwise?
Old 02-28-2002, 02:11 PM
fritz_269's Avatar
Uh, just curious if this is what you meant to say... advancing the exhaust will increase overlap.
Old 03-02-2002, 11:47 AM
drift's Avatar
and advancing the the intake slightly will also decrease overlap
Old 03-02-2002, 10:00 PM
that's it...advancing/retarding, something. i'm probably just used to the idea of advancing OHV/SOHC cams.
AEM ColdAirIntake
Nitto 450 225/50
LS/VTEC Turbo, H22 TURBO, B20 Turbo....which one? 92HBsi JDM Motor & Parts info/chat 8 01-21-2006 01:11 AM
LS/VTEC Turbo, H22 TURBO, B20 Turbo....which one? 92HBsi N2O | Turbo | Superchargers 5 01-08-2006 10:40 PM
is turbo h22 a bad idea? born khatarnak JDM Motor & Parts info/chat 12 07-03-2005 01:59 PM
All motor H22 vs H22 turbo? JDMugenKid Let's get Technical! 6 01-30-2004 11:32 PM
