Old 02-25-2002, 05:59 PM
G.T.i.R G.T.i.R is offline
Metallic Paint
What is the best way to remove the "eggshell" effect on metallic paint (holts duplicolor). Its had at least 6 coats but i don't want to ruin it with rubbing compound. Thanks
Old 02-25-2002, 06:02 PM
Guiddy's Avatar
Guiddy Guiddy is offline
What do you mean 'eggshell'? Is it cracked?
Old 02-25-2002, 06:07 PM
No i was talkin about the fine pimply surface texture you get after spraying metallics.
Old 02-25-2002, 06:10 PM
Guiddy's Avatar
Well, then you use rubbing compound! Why on earth do you think you would ruin it!!!
The thread on painting covers the use of rubbing compound. Depending on where you are decides which compound you can get!
If it is really rough a rubbing with the finest wet & dry papers will also speed the process up, they I don't recommend it for beginners!
Old 02-25-2002, 06:37 PM
daggerlee's Avatar
Pretty much, you will need to rub with something like 600 or 800 grit to get rid of the "Orange peel" as it is referred to as. You can then follow Guiddy's method of using a cutting compound or you can rub with successively finer grits (micromark.com sells a 2400, 3600, 4800, 6000, 8000, and 12000 grit kit).
You have 6 coats of paint so you shouldn't worry too much about rubbing to the primer, but be careful at sharp edges!
Hope this helps
Old 02-25-2002, 06:48 PM
Guiddy's Avatar
I wouldn't go as rough as 600 or 800 on the final finish. Even with 1200 I have had swirl marks I couldn't get rid of.
If you can't get those micromark papers just use compunds, first a harsh one then a nice smooth one.
Old 02-25-2002, 06:56 PM
hirofkd's Avatar
hirofkd hirofkd is offline
It depends on the brand, but rubbing metallic paint will probably result in nasty stains, so I don't recommend it. Metallic paint is a mix of fine metallic pigments, clear and solution. I think the egg-shell effect is caused by the lack of clear in the metallic paint. Add clear and thinner to the metallic and test spray to see how much they should be added. This, I can't help, because it highly depends on the experience.
Good luck.
Hiroaki Fukuda
Old 02-25-2002, 07:22 PM
Guiddy's Avatar
Egg shell isn't a problem on metallics as the lacquer will fill out an roughness!
Just go with a few coats of lacquer and then polish that using compound
But you don't want to be putting 6 coats of basecoat and THEN lacquer too!
Just two or three is fine.
Old 02-26-2002, 01:56 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Exclamation
No no no!
Don't use rubbing compound on metallic paints. At least before you apply clear coat. If you do it to the paint, it will take off the top laquer (or something) and it will leave the paint looking too much like copper. Had this problem with my 300ZX, but I ain't redoing it - it took me too long to mask all the stuff on that car.
Old 02-26-2002, 04:52 AM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
I didn't have any problem with the metallic I used on the 360 spider it shine up good without any clear coat
Old 02-26-2002, 06:06 AM
daggerlee's Avatar
Did you apply a clearcoat after it?
Old 02-26-2002, 02:38 PM
ales's Avatar
Forza Schumacher
No, and that was my problem! I used motorcycle acrylic spraypaint, and then I did the door lines and tried to remove some excess with rubbing compound. It's not too bad, but still there is quite substantial effect.
Old 02-26-2002, 05:01 PM
daggerlee's Avatar
Wow, I had the same problem with my 300ZX (my first model too, go figure :P). I tried doing the panel lines and the paint got all smeared and wouldn't come off with thinner.
You should apply a clearcoat, it should restore the metallic finish
Old 02-26-2002, 06:00 PM
ales's Avatar
Forza Schumacher
Thought about it. But it will ruin my perfect semi-gloss black parts (do you have any idea how long it took to mask that?) maybe I still will do it anyway
Old 02-26-2002, 06:03 PM
Guiddy's Avatar
Do you guys think I need to do a thread on painting metalics?
Dark Grey Metallic paint code anyone...help?? Mr2KiEu C/K 1 11-26-2003 05:24 PM
metallic paint question... Kasso Car Modeling 6 10-20-2003 05:07 PM
Panellines disappear after metalic paint + clear coats...... yellow15 Car Modeling 4 06-11-2003 07:19 PM
does metallic paint look grainy WHIZ Car Modeling 6 01-17-2003 03:35 PM
metallic paints hakka Car Modeling 2 01-19-2002 06:08 PM
