Old 11-18-2004, 12:29 PM
globetrotter globetrotter is offline
Talking how to paint spokes of deep dish wheels ?
How can i paint the spokes of my zakspeed capri ?
see it at www.hlj.com/scripts/hljpage.cgi?tam24274
Thanks in advance
Old 11-18-2004, 12:35 PM
freakray freakray is offline
AF Modelrater
Re: how to paint spokes of deep dish wheels ?
My recommendation would be to use liquid mask to mask them and then airbrush, or you could just carefully brush paint them.
AF User Guidelines
Old 11-18-2004, 01:46 PM
primera man's Avatar
"P-Man"
I have just brought this kit this week.
Have looked at the rims and i'd just use a light coats with a brush
View All My Models Here.
Old 11-18-2004, 02:48 PM
nervestrikes's Avatar
nervestrikes nervestrikes is offline
Paint carefuly, that what I did and it didn't turn out too bad.
Old 11-19-2004, 12:55 PM
Thanks for the replies. airbrushing is out of the question since i don't have an airbrush.
If i would paint them with a brush. What kind of paint schould i use enamel or acryl. Cause a friend of me advised me to paint them with acryl (does it excist in gold anyway). But i think acryl would be to runny to paint the spokes with since the rim is chromed and the surface is super smooth.
I guess the best option would be masking with maskol (liquid mask) and paint them with enamel.
Old 11-19-2004, 01:30 PM
Vric's Avatar
Vric Vric is offline
I would say Enamel since it take longer to dry and will hide a bit brush stroke
but it's depend also of what paint you will use under this paint
Old 11-19-2004, 01:52 PM
What ever Tamiya paint is that is what I used. I thought worked pretty well.
Old 11-19-2004, 01:55 PM
Jumpman_Z's Avatar
Jumpman_Z Jumpman_Z is offline
Send a message via AIM to Jumpman_Z
Just use the smallest brush you can get, and try not to hit the rim. I like to let the paint it on the brush for about 20-30 seconds, so it can start to cure. This helps to keep the paint from running.
Air 23 - News, release dates, info, tons of pics, and much more!!
Air Jordans
Air Jordan release dates
Z33, 287 hp, 274 lb/ft torque. 'Nuff said.
Old 11-19-2004, 03:41 PM
proosen's Avatar
proosen proosen is offline
If you brush paint with acrylic colours you can always clean up over paint with a alcohol moisted brush. As the chrome even withstands white spirit you can use enamels to and tidy up the work before it set. So don't worry, just relax and do it with a brush if you like. For spraying you just mask it of with liquid mask or Tamiya tape like I have done on the one below and spray it with your favorite can.
Niclas
Old 11-19-2004, 04:22 PM
Murray Kish Murray Kish is offline
Getting Old...
I've had some pretty good luck using Silly Putty or Blu-Tak to mask and airbrush stuff like this. It totally conforms to any shape easily, and it can be 'pushed' or 'pulled' into place with a toothpick (I use a narrow putty knife).
Using a spray can is a bit risky, because the paint goes on pretty wet and there's a risk of it 'melting' the silly putty (turns all soft an gooey...)
Murray
Old 11-20-2004, 11:39 AM
Ok thanks for the replies. Does any off you guys now how i schould paint the yellow dunlop marks on the tyres ? I was thinking of using a Tamiya paint marker.
