Old 11-18-2004, 09:18 AM
cooltc2004's Avatar
cooltc2004 cooltc2004 is offline
Send a message via AIM to cooltc2004
quick question bout primer
All over in the FAQ it says that primer is a must, and everytime i see you guys do models, you all use primer.
What kind of primer do you guys use? I need something that doesnt fill in, because wont that fill in around little details as well?
Old 11-18-2004, 09:30 AM
primera man's Avatar
"P-Man"
Re: quick question bout primer
Tamiya surface primer in either white or grey
View All My Models Here.
Old 11-18-2004, 09:31 AM
freakray freakray is offline
AF Modelrater
It will only fill in details if you spray it on too heavily, just the same as any color quote would.
I use Tamiya primers mostly, but also Duplicolor automotive primer.
AF User Guidelines
Old 11-18-2004, 09:35 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
If you are shooting enamels (like Testors for example) over a stock unmodified body, I'd skip the primer. If you are using lacquers (even the mild Tamiyas) you'll need a primer for adhesion and for some of the more aggressive lacquers, for protection against etching.
I like the Tamiya Fine White Primer. It's thin and usually there is no need to sand between priming and painting. Gunze Sangyo has some too that are very fine. Also Krylon gray works well and is cheaper, but is much heavier. - Mark
Old 11-18-2004, 11:39 AM
Spitfire7's Avatar
Spitfire7 Spitfire7 is offline
I can't get tamiya primer in the uk, so i use halfords plastic primer.
Old 11-18-2004, 03:40 PM
RallyRaider's Avatar
Zomby Woof
I use GSI Creos (Gunze Sangyo) Mr Surfacer. It comes in different "thicknesses". The 500 is great to brush on and fill small surface imperfections the 1000 I airbrush as a primer. As mentioned above the trick is to keep it very thin, which is easy with an airbrush but possibly a bit trickier with a rattle can. GSI Creos also have a new Mr Surfacer out, 1200 that I guess is even finer.
Old 11-18-2004, 05:40 PM
geofroley geofroley is offline
Send a message via AIM to geofroley
I use Duplicolor Automotive White primer and Varsity Automotive Primer. Avoid Testors or Model Masters primer.
Old 11-18-2004, 09:48 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
I use dupli-color primer to, it goes on nice and thin
