Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-25-2002, 05:45 AM
MaGR MaGR is offline
Send a message via ICQ to MaGR
VTec Hard on engines?
Hey.......
I've been thinkin about getting an Integra 94-97 age group for a while now..
Except I was talking to someone the other day and said that Vtec is really hard on the engine and won't last as long as a normal non-Vtec engine???
His friend has a 96 Intega and it's allready smoking........
This true or not?????
Old 02-25-2002, 11:50 AM
Speechless Speechless is offline
Well, yes and no.
Since it's a performance engine, and it has higher compression then it will likely go thru more stress than lower compression engines.
But with that in mind, it's obviously built to withstand higher compression & stress, and Honda (one of the best engine manufacturers in the world) would be absolutely retarded to build a high performance engine that could not withstand high performance, so I think your friend needs a good kick in the nuts for good measure.
Get the vtec. It's good for you.
:help:
AF Nordic Crew - #16
I EAT TREES YO...I EAT TREES!!!!
Old 02-25-2002, 02:52 PM
97teg 97teg is offline
speechless is right. the only reason a gsr or type r would wear out faster is if you have a fast car you will drive it hard and rag it out. but thats true for all cars, vtec has nothing to do with it wearing out faster. give him two kicks
Old 02-25-2002, 05:19 PM
T.O.tegs T.O.tegs is offline
the higher you rev an engine and the more frequently you take that engine to high rpms will deffinetly affect the engines life span...
I agree that GSR/SiR engines will not last as long as say a B18A/B...if both engines are driven the same way, the non-vtec engine will last the longest....
now that said, Honda makes very very very strong motors so 200K out of either vtec or non vtec is easily done....
WUTS DAT
AF nordic #7 foo...you better recognize:finger:
02 Grand Am Hard Start when engine warm. ajbtrugreen Grand AM 3 08-01-2010 01:06 PM
should i tune a 98 honda integra dc1, sohc, non vtec, zc engine keith2000 Let's get Technical! 3 11-16-2007 08:58 PM
should i tune a honda integra dc1 sohc non vtec zc engine keith2000 How-To's and Walk-Through's 1 11-14-2007 07:39 PM
ls vtec turbo engine NEW aznbmxxxer Classifieds 0 05-06-2006 03:46 PM
Vtec on engine block in 92? Dons92CivicVX '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 08-08-2003 12:52 AM
